Deep grove pulleys on 73 z28 with AC ???
Discussion in '1970 - 1973 Specific' started by Crazy4camaro, Jun 15, 2017.
  1. McCune
    McCune Veteran Member
    894
    137
    Aug 22, 2015
    st.george utah
    The 73 non A/C Z28s have the same pulleys as the LT1 excluding the alternator.
  2. 70 SS/L78
    2,555
    58
    May 5, 2005
    Rockford, MN
    Thanks for correction. ;)
    McCune likes this.
  3. twozs
    twozs Veteran Member
    8,783
    163
    Aug 5, 1999
    hopewell jct ny
    It was more or less to do with the rear gear with the z28 . With air is a 3.42 with out 3.73 . You can get any engine to spin 7 grand solid lift or not . Is it still making power , doubtful . The compressor is good to about 6000 rpm before it possibly detonates . Compressors were expensive to replace under warranty . Reducing the max rpm ( in gear ) help for this . There was AC on the solid lift LT1 vette in 72 due to demand.
  4. Crazy4camaro
    Crazy4camaro Veteran Member
    260
    34
    Dec 30, 2015
    Greenville SC
    This is the 73z pulleys
  5. Crazy4camaro
    260
    34
    Dec 30, 2015
    Greenville SC
  6. Crazy4camaro
    260
    34
    Dec 30, 2015
    Greenville SC
    1973 LT Z28 65000 miles
  7. 70lt1z28
    2,476
    365
    Oct 3, 1999
    Beavercreek, Ohio, USA
    On the 72 Vette LT-1 with air the tach had a reduced redline of 5600 to save the compressor.
  8. Crazy4camaro
    260
    34
    Dec 30, 2015
    Greenville SC
    Im glad you brought up tachs, This one has a 5000 redline. Is it correct for the ac cars????
  9. twozs
    8,783
    163
    Aug 5, 1999
    hopewell jct ny
    [​IMG] Not really . It was only available with auto trans and 3.55 rear was the steepest and only gear available . Unless you got something that says it had an electronic rev limiter. Hell , it still had points in 72 .
  10. twozs
    8,783
    163
    Aug 5, 1999
    hopewell jct ny
    all Z28 [​IMG]
