Death wobble after drag run 73 Camaro
Discussion in 'Competition Camaros' started by CAM502, Jan 16, 2018.
  1. CAM502
    CAM502 New Member
    Jan 16, 2018
    Hi All, I'm wanting to solve a death wobble I get after I lift off at the end of a drag race.
    The car seems to steer itself from side to side, it's only slight but it's quite off putting as it happens at around 130mph
    Since the car has been restored, all new suspension, springs, bushes have been used
    So I thought I should start by comparing what wheel alignment other Pro Street style 73' Camaros are running that also run frequently at the drags
    My wheel alignment looks like this Toe=0, Caster=1.23, Camber=0
    I run regular radials at the front, and MT Drag radials at the rear
    Thanks for any help
    Regards
    Robert
  2. rustorbust
    rustorbust Veteran Member
    241
    10
    Dec 14, 2009
    San Diego
    I have had this happen in the past with cars and typically they need a little bit of Toe in. Try an 1/8" in.
    CAM502 likes this.
  3. CorkyE
    9,768
    309
    Agree on a whisker of toe in, think we shot for 1/16 on mine.
    CAM502 likes this.
  4. harbone66
    3,500
    284
    Feb 15, 2011
    Central Illinois
    Were you on the brakes at all?
  5. bracketracer-78
    bracketracer-78 Veteran Member
    696
    36
    Sep 5, 2003
    Stevens, PA USA
    At zero toe at ride your toe is going out when you let off and the front dives down. I think mine is set at 1/16th of a inch at ride height. I know when the front end comes up my tires toe in more, I think 1/8 per inch, but don't quote me on that. I set the toe myself about 15 years ago.
  6. SRGN
    SRGN Veteran Member
    569
    180
    Feb 20, 2009
    Central NJ
    Mine got hairy with radial fronts and bias rears. Try bias fronts.
  7. CAM502
    CAM502 New Member
    Jan 16, 2018
    Hi, not on the brakes, just lifting off brought this on, accelerating again made the sway stop
  8. CAM502
    CAM502 New Member
    Jan 16, 2018
    I've never mixed Radials and Crossply's
  9. John Wright
    14,406
    128
    Aug 9, 2002
    Rustburg, Va
    More caster would help give the steering a heavier feel and help it find center.
    Take away that shopping cart feeling....;)
  10. muscl car
    Running drag radials at very low press will cause the car to get loose thru the lights once off the throttle , try going up in air pressure
