DASH LEDS for 79 camaros
Discussion in 'Tips 'n' Tricks Topic' started by DEE$2017, Sep 17, 2017.
  1. DEE$2017
    DEE$2017 New Member
    9
    Jul 24, 2017
    Does anyone know what Leds would work in place of the oem bulbs or have done this all ready maybe. I would like to change color in dash to blue without changing out to new to new aftermarket gauges.
  2. budro6968
    budro6968 Veteran Member
    2,665
    363
    Apr 2, 2016
    Jax Florida
    E-Bay has dash LED upgrade kits that are plug and play. probably any color you want. 8.99 plus ship. I could not get the link to copy and paste. Just Type in your year and Camaro Dash light upgrade to LED.
    DEE$2017 likes this.
  3. 70 Proof
    70 Proof Veteran Member
    427
    29
    Sep 28, 2014
    Southern Utah
    Do an internet search for LED's using the pn of the bulb you want to replace. I.e. 194 LED
  4. rchydzik
    803
    16
    Nov 13, 1999
    Colbert, WA USA
  5. hd_cat
    hd_cat New Member
    8
    Sep 6, 2013
    United States
    The replacement LED for a conventional 194 is correct, if you can find dimmable LEDs you might be happier than with those that only light to full intensity. I installed them in the '79 Z/28 earlier this year and they're pretty bright! You'll also want to check each socket to be sure your connections are good, I had to bend most of the tabs to have better contact with the printed circuit. Your signal bulbs are likely to flash more rapidly as the LEDs have less resistance than a conventional bulb
  6. Mr Sunshine
    Mr Sunshine Member
    89
    Dec 12, 2016
    Missouri
    From what I've read on changing to LED bulbs it requires a special LED flasher for turn signals due to the low amp draw of LED bulbs. I haven't done this yet so I don't know if this is a must or a sales pitch. Anyone else have the experience of going to LED turn signal bulbs?
  7. Twisted_Metal
    26,216
    581
    You only need the electronic flasher if you change the signal light bulbs.
    The dash "signal indicator" bulbs will work fine with the factory flasher.
  8. hd_cat
    hd_cat New Member
    8
    Sep 6, 2013
    United States
    Yes, the LED bulbs should be the replacement version of the #194, I installed a set in the '79 Z/28 this year. The bulbs are very bright and if the version you chose is not dimmable, they'll be bright 100% of the time. Be sure to buy the resistor as well, the turn signals flash very quickly. You may also experience issues in trying to get them all to light. I tweaked the contacts in nearly every socket both to get them to contact the printed circuit, and to contact the bulbs correctly. Good luck with yours!
