Cowl drain holes
Discussion in 'Camaro Questions' started by Jeep43, Feb 18, 2018.
  1. Jeep43
    Jeep43 Veteran Member
    1,056
    16
    Mar 30, 1999
    Connecticut
    DSCF9719.JPG As I was drilling out a snapped lower fender bolt I noticed a blank hole nearby. As I poked inside with a screwdriver tons of dirt and debris came out. I presume this is the hole that the cowl drains from (and collects rot inducing debris).
    I'm thinking about enlarging the hole to maybe 1" to help get the 40+ years of crap out. I'll clean out as much as I can now and through driving it any water that gets down there can help flush out the rest. When I take the car apart in a couple years for a full body resto, I'll spray some anti rust Any reason why not to? This hole is covered by the lower part of the fender when installed.....
  2. Jeep43
    1,056
    16
    Mar 30, 1999
    Connecticut
    I tried picking bits out but I would be there forever trying to break chunks up. I ended up passing a 3/4 unibit thru there to max it out to 3/4. The drivers wasn't too bad but when I drilled the pass side, and stuck my finger into the hole it was blocked, except for the conical void where the step drill went in. All packed dirt. I also passed a cut air line down thru the cowl down to the bottom and plugged it into 100 psi with a shop vac attached to the 3/4 hole. I was still having trouble having to break some of the larger chunks up to get them out of the 3/4 hole.
