correct Carburetor
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by Eaglefixer, Sep 8, 2001.
  1. Eaglefixer
    Eaglefixer Veteran Member Lifetime Gold Member
    1,574
    Feb 25, 2002
    Warner Robins, Ga
    Hi, I'm trying to put my 1970 Z-28 Back close to original as i can. I have the carburetor off of it and has the numbers 3310-2. and its a Holly. Can anybody tell what carb is suppose to be on it. Its got the 350 LT1 engine with 4 Speed M-21.
    Thanks
    Steve
  2. 76'maro
    76'maro Veteran Member Lifetime Gold Member
    3,200
    Mar 25, 2000
    Jacksonville, NC, USA
    Moving to Decoding Topic!!...
    [​IMG] The Management
  3. 76'maro
    3,200
    Mar 25, 2000
    The number you have listed apears to be a Manufacturer's List #, and should have been stamped on the front of the primary barrel air horn, on the driver's side. The first number should have been a part number, perhaps 3878261 EH? After that would have been the 3310-2 number you listed, which identifies it as a 1965 Chevelle SS396 (375 hp Z16, manual transmission) carburetor. Just below that would have been a date code.
    The correct carb for your 1970 LT1 (non California) is a Holley model 4150, GM part #3972121, List #4555. The primary metering block should be stamped 6333, and the secondary metering block should be stampted 4519, with NO idle vent. The Cali LT1 used a different list number. If you have a Cali engine, I wil post those ID nubmers for you as well.
    1976 Type LT Restification (in progress)
    1968 2 door sport coupe...the toy!
    1971 Camaro RS, all original, 1 owner...wife's baby!
    1970 Chevelle SS396...all ORIGINAL!!! (and it looks it right now, too!)
    American Muscle Cars: THE resto shop
    The Monday Nite Car Club! (New site)
