Correct Alternator wiring routing 72.
Discussion in 'Electrical Systems' started by biggrass, Nov 19, 2017.
  1. biggrass
    biggrass Veteran Member
    338
    Aug 30, 2006
    GURNEE, IL
    I have a 72 and the alternator wiring bundle is routed as you can see from the picture incorrectly. Just wondering if anyone has a picture of the correct routing. Also if it needs to be routed different where could I get the correct length wiring, or can it be spliced? Correct gauge of wires? Thanks Dave IMG_0691.JPG
  2. muscl car
    Mine is routed between the intake manifold and upper rail of the valve cover and using wire hold downs attached to the two valve cover bolts
  3. bodymanbill
    bodymanbill Veteran Member
    745
    114
    Feb 1, 2007
    South Park Pa
    image.jpg image.jpg Here's how my 73 is routed, not sure if 72 is different or not
