Cooling system sound
Discussion in 'Troubleshooting & Diagnosis' started by GPN, May 11, 2017.
  1. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    Will sounds ever go away? I've put on about 800 miles. Someone suggested I get the front end up a bit, & burp system
  2. rocket dawg
    rocket dawg Veteran Member
    256
    14
    May 5, 2015
    Grand Rapids Mi
    Maybe reverse the heater hoses? Otherwise a pressure test of the system might reveal something. Does it have an overflow tank?
  3. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    I do have an overflow tank. I purchases a no-spill funnel & followed that "burp" procedure. Seems to have worked
  4. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    Thought I had resolved problem with funnel procedure. I’ve done it twice, still get coolant pops. Notice when I idle care befor turning off, and when it turns off, still popping several times. Otherwise car runs fantastic. It drives me nuts. Gotta think it can’t be good for engine
  5. rchydzik
    787
    14
    Nov 13, 1999
    Colbert, WA USA
    If the system is full and not leaking, you should be able to squeeze the upper radiator hose with your hand and watch coolant move in and out of the overflow bottle. Do this when the engine is cold. If you don't see that, there is air in the system or a pressure leak somewhere else or it is not full cold.
  6. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    Just tried that. Coolant did not move. When you say pressure leak—wouldn’t I see coolant leaking somewhere? I drive car a lot (thank you for your response)
  7. rchydzik
    787
    14
    Nov 13, 1999
    Colbert, WA USA
    If you can squeeze the hose, and it is leaking, you should be able to hear it somewhere. My guess is that the radiator is not topped off, and that is why coolant is not moving in and out of the overflow. Try topping it off cold, and squeezing the upper hose after that. You should see some sputter towards the overflow tank. Be sure the overflow tank is between min and max.
    If coolant does not move after all that, run it up to operating temperature so the coolant expands. Try it again.
    An easy way to burp the system is to drill a 1/8 inch hole in the thermostat. It will allow air to pass when filling, but very little coolant to flow when running until the thermostat opens.
  8. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    thank you
  9. COPO
    16,581
    308
    When you have an overflow tank, the rad needs to be filled to the top and the overflow bucket filled to the cold level. Once you drive and it cools off, if the rad level is down, it will suck what it needs from the overflow tank into the rad. If it does and the overflow tank gets lower than the full line, then simply top up the overflow tank with 50/50. At this point the rad will be showing full if the cap is removed when cold.
  10. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    Thank you
