Cooling system sound
Discussion in 'Troubleshooting & Diagnosis' started by GPN, May 11, 2017.
  1. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    succesfully installed new water pump & clutch fan over weekend. Added coolant, burped & car running fine & temps are right & steady. But I hear a muffled knocking from System when driving. No sound when I turn car off
  2. CorkyE
    9,049
    170
    Double check that fan is tight on hub.
  3. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    Thank you. Checked-tight. And I guess I didn't listen close enough. It makes this noise after I shut off, but only for about 10 or 12 seconds
  4. slayer021175666
    slayer021175666 Veteran Member
    1,155
    54
    Feb 29, 2016
    Idaho
    Might just be water settling. Might still have a little air in there so, just keep filling radiator if the coolant level drops. I don't think its much to worry over. Many engines make a few (COOL IN MY OPINION!) sounds as they cool down.
  5. CorkyE
    9,049
    170
    Yep, like slayer said, just air working around in the system. It'll work itself out.
  6. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    Ok, glad to hear
  7. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    Good, tnx
  8. Twisted_Metal
    25,455
    348
    Sea Monkeys...
    They should cook down with no further problems. ;)
    You're good because you know to watch the coolant level and temp until they're gone.
  9. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
  10. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
