Compressor question.
Discussion in 'Garages, Workshops & Tools' started by RedSpider, Oct 17, 2013.
  1. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    IR has some of the most reliable compressors on the market, as does Quincy. I have personally dealt with IR for a head rebuild.....great people to deal with and awesome customer service.
    Another thing to think about when buying a compressor....
    Parts availability.
    Good luck!
  2. Krator
    Krator Veteran Member
    381
    Apr 24, 2013
    I bought one that I think used to be sold at TSC stores here in Ontario, I picked it up at The TOol DOctor here in town for $650. 14.6 CFM at 120 pounds. and an 80 gallon tank. Will do everything I need it too and more.
  3. Goodwrench1965
    Goodwrench1965 Veteran Member
    871
    23
    Apr 23, 2010
    Charlotte NC
    A 2 stage compressor like you suggested has higer pressure and lower air delivery / cfm than a comparable power unit. The tools you indicated need volume and not the pressure of a 2 stage compressor. Go with a single stage unit with the highest cfm for the money you want to spend. A vetical tank takes less space than a horizontal one and bleeds condensation better. A belt drive tends to start better / trip brakers less often than direct drive. A name brand compressor is like any other tool there will be higher quality and better back up worth the money. Consult a local compressor service vendor like ones that back up pro shops and hospitals for knowledgeable folks on the issue.
