Compressor question.
Discussion in 'Garages, Workshops & Tools' started by RedSpider, Oct 17, 2013.
  1. RedSpider
    RedSpider Veteran Member Lifetime Gold Member
    193
    Oct 25, 2011
    Heber Ut.
    Not sure if this question belongs here or not.
    Anyone own one of these husky compressors? Or should I look for something better?
    http://www.homedepot.com/p/Husky-80-Gal-5-HP-2-Stage-Air-Compressor-HS5181/100005910?cm_mmc=sem|psocial|fbx|dynamic
    Buget is 1500.00 max
    I want it for painting, sanding and tool use.
    Thanks for your input.
  2. cmonson
    cmonson Veteran Member Gold Member
    4,134
    Apr 7, 2006
    Calgary, Alberta
  3. RedSpider
    193
    Oct 25, 2011
    Heber Ut.
  4. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
  5. Zazoos
    Zazoos Member
    40
    Apr 15, 2012
    Longview Texas
    I have the one that Sevitz5 listed from Tractor Supply. I have been sandblasting with it using a pressure pot and it maintains pressure with a 3mm tip pushing #5 blasting sand just fine. However, when the tip starts enlarging the compressor falls behind. If I was to do it again I would probably go with the next size up compressor.
  6. BonzoHansen
  7. hhott71
    hhott71 Veteran Member Lifetime Gold Member
    14,375
    Mar 30, 2001
    Joplin Mo. 64801
    My 30 gal 5 hp comp was bought at an industrial supplier before I bought my business in 1988 It was plugged in any ready at all times. We painted 3 cars, a acouple of times each at least too. We never can low on air.
  8. 351maverick
    351maverick Veteran Member
    3,069
    151
    Aug 11, 2010
    erie, PA
    agree - buy that one
    I have the exact same compressor in my garage that I use almost daily, mostly for media blasting in a Snap On cabinet
    mine is 8 years old & still works perfect
  9. Gary S
    20,804
    223
    Any of those 5hp compressors should work fine for you. Get the best deal you can. A 5hp compressor will deliver 15-18 cfm at 100psi, and that should do about any job a home hobbyist needs.
    Shopping just by brand isn't what it used to be. Most compressors today are either Made in China, or assembled in the US, Canada, or somewhere else using Chinese parts. There isn't as much difference in quality as there was 40 years ago. Often, the cheap one will perform for you just as well as the big name one.
  10. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    I agree w ith Gary..........if you take your time and shop around you should be able get one for around $800.00 new. you could always try craigslist too.
