Compressor Oil Change
Discussion in 'Garages, Workshops & Tools' started by Zstar, May 25, 2014.
  1. Zstar
    Zstar Veteran Member
    1,206
    248
    Mar 23, 2014
    Ocala, Florida
    How often should I change oil on a two stage, 6 hp, 80 gal compressor that sees maybe 4-5 hrs of use per week. Thanks in advance.
  2. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    I have never changed mine.....like 30 years!!!! Don't take hey advice! :)
  3. sickfast1964
    sickfast1964 Veteran Member
    442
    12
    Aug 26, 2012
    Corinth, Tx
    Probably once a yr. more if it runs all day in a commercial setting.
  4. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    Once a year is a good idea for most of us.
  5. Gary S
    21,078
    305
    It depends on what oil you use. If you use petroleum based oil, I'd change it every 2-5 years. If you use synthetic oil, change it only if it gets dirty looking or you exceed the 8000 hour rating of the oil. But, most home grade compressors have pumps that aren't rated much over the 8000 hour rating of synthetic oil, so you probably never have to change synthetic.
  6. 68400BIRD
    68400BIRD Veteran Member
    2,950
    9
    Feb 7, 2006
    GO PACK GO
    I change mine yearly.
  7. 69TAPoser
    69TAPoser Veteran Member
    672
    Nov 24, 2008
    Windham, NH
    Your manufacturer should have a recommended cycle based on time/usage.
    We are in a very high-use commercial situation at our shop, using a very large 15hp Saylor-Bealle 4 cyl compressor that holds 200 gallons. We run synthetic compressor oil (Amzoil) and change it every 90 days.
    I would think an annual change would suffice for most, but it depends on usage and how much dirt is getting in the oil.
    Also make sure that you are using compressor oil (which is non-detergent).
    Phil
  8. Zstar
    1,206
    248
    Mar 23, 2014
    Ocala, Florida
    Thank you all for your input. I will change to Amxoil.
