Compressed head gaskets worth it?
Discussion in 'High Performance Modifications' started by Soundwave, Oct 30, 2017.
  1. Soundwave
    Soundwave New Member
    19
    Apr 26, 2017
    Hi Guys! Going with edelbrock 100cc heads with flat tops. Compressed head gaskets a good idea? Shouldbe 9.2 to 1 with those heads... thanks! Oh, 468 big block
  2. Mwilson
    Mwilson Veteran Member
    I pick my gasket based on piston to head clearance. Cant remember exactly I think i'm .009 piston to deck and .030 MLS gasket
  3. SRGN
    SRGN Veteran Member
    515
    160
    Feb 20, 2009
    Central NJ
    That pretty much covers it. Look up squish & quench on google to understand the theory.
  4. CorkyE
    9,583
    273
    Do you mean composite head gaskets? Unless you're going to use a power adder, then no, stick with good old Fel Pro's.
  5. HawkX66
    HawkX66 Member
    84
    22
    Sep 20, 2017
    MI/MA
    Don't just change you're gasket thickness without checking your piston to valve clearance.
    Mwilson likes this.
  6. G72Zed
    G72Zed Veteran Member
    536
    51
    Sep 8, 2015
    X2 ^^ All head gaskets compress to a point, whether it's steel shim, composition or MLS (multi layered steel). Like CorkeE said, look at Fel Pro's, the #1027 are noted as "no brinneling" on aluminum heads
  7. 70lt1z28
    2,323
    336
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I would venture to say that you would be hard pressed to get a steel shim head gasket to compress much more than 0.0002. Once the beads deform, the flat steel is effectively non-compressible under bolt torque. To compress the flat steel, it would effectively be coining it and would take a few hundred TONS of pressure for an area this large.
  8. Mwilson
    I'm not reccomending any gasket type that will be based on your application I'm only describing how I determine my required gasket thickness
  9. 70lt1z28
    2,323
    336
    Oct 3, 1999
    0.009 seems kind of thin. What is the accepted minimum? I know aluminum rod motors are much more.
  10. Mwilson
    .009 is piston to deck my gasket is .030 for a total of .039
