Composite leafs
Discussion in 'Custom Works' started by kimosabi, Oct 22, 2014.
  1. kimosabi
    kimosabi Veteran Member
    754
    Oct 7, 2013
    Not
    Hi, anyone used the composite leafs? Would you recommend them for a "normal" ride "normal" use, Keith?
    Cheers!
  2. ks71z28
    ks71z28 Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,120
    24
    Oct 10, 2004
    chico, ca, usa
    We usually recommend them for "normal" use. The only draw back is the cost. The ride is amazing smooth, yet firm, and quiet. They have a great feel. Also you MUST use an adjustable shock with these, due to the characteristics of a composite spring.
  3. Zspoiler
    Zspoiler Veteran Member
    2,894
    186
    May 6, 2012
    Federal Way, Washington
    If you are going to have a healthy engine you will break them.
  4. DB Z28
    DB Z28 Veteran Member
    546
    36
    Nov 30, 2003
    Fond Du Lac
    I had two sets and broke both of them. Unless they changed they were dangerous to have with a hi Hp car.Mine were from vette products.
  5. kimosabi
    754
    Oct 7, 2013
    Not
    I'll Probably be about 450hp, 400-450lb/f on a posi 3.42 gear w turbo 350. Would I be pushing it?
  6. ks71z28
    2,120
    24
    Oct 10, 2004
    chico, ca, usa
    The Vette products were too soft and a poor design. We ran ours with 550 hp and used them very are for 3 seasons and now they live on in a customers car. They were designed for dirt track racing and nothing is more abusive than that
  7. Lowend
    14,710
    350
    Mar 25, 1999
    San Jose, CA, USA
    curious if you have a plan for a custom valve steady-state shock? It seems likehaving an off-the-shelf solution for composite springs would be a huge boon in the market
  8. ks71z28
    2,120
    24
    Oct 10, 2004
    chico, ca, usa
    Not at all.
  9. ks71z28
    2,120
    24
    Oct 10, 2004
    chico, ca, usa
    We have several shock options, all of which are rebound adjustable, which the composite spring needs way more than a steel spring. We sell about a dozen pairs of these a year, which isn't enough to invest in a dedicated custom valved shock.
  10. kimosabi
    754
    Oct 7, 2013
    Not
    One more question, do the composites require a watts link?
