Code 15 check engine light
Discussion in 'Troubleshooting & Diagnosis' started by 81zapper, Aug 27, 2017.
  1. 81zapper
    81zapper New Member
    23
    Sep 19, 2006
    Stoney Creek Canada
    i know this means a problem with cooling sensor
    Where is the sensor located. I know there is a sender and a sensor
    What does the sensor look like (not the sender)
    Any help would be great
    1981 z-28 is the car
  2. Joekool
    Joekool Veteran Member
    5,863
    22
    Feb 4, 2002
    Hollister CA USA
    A temp sensor will have two wires going to it and either be located near the thermostat or on the side of the cylinder head. If you see a single wire, that's the sender for the gauge.
  3. 74BIBELOT
    74BIBELOT Veteran Member
    Yea, it's a two wire sensor, usually a yellow and black wires, looks like this:
  4. 81zapper
    81zapper New Member
    23
    Sep 19, 2006
    Stoney Creek Canada
    Thanks every one got it
    It's
    Mounted On thermostat housing
