Clutch return spring w/headers
Discussion in 'Transmission & Driveline Topics' started by Green hornet, Feb 16, 2017.
  1. Green hornet
    Green hornet Veteran Member
    609
    61
    Oct 11, 2015
    North Bay, CA
    I just installed my new Hedman headers today and found that the clutch return spring rubs on the header pipe. They are ceramic coated so I don't like. Who can post photos of how they solved this issue. I did a search but was unable to view any photos of what others have done.
    70 Camaro sbc with a Muncie. Thanks.
  2. BonzoHansen
    I use a different spring i got at the hardware store and ran it to a different spot on the frame
    Only pic i can find right now
  3. grzewnicki
  4. giggity
    giggity Veteran Member
    614
    10
    Mar 18, 2013
    Pearland, texas
    There should be 2 holes in the frame, I just ran my spring to the other hole, no clearance issues now. I would also recommend you using dual springs.
  5. BonzoHansen
    I never thought of dual springs. Interesting. I have to do some underhood work soon, I will check that out. What springs did you use?
  6. giggity
    614
    10
    Mar 18, 2013
    Pearland, texas
    Ill try to remember to take a picture of it when I get under car this weekend. But I used the standard return spring, and then bought a bigger return spring I found at Summit so both are on, spring pressure is good, not too tight, depends on where you adjust it. So far it works good. Ive broken one of those years ago, and had to drive home in second gear, which was interesting. might be overkill, but it works for carburetors!
  7. Zspoiler
    Zspoiler Veteran Member
    I just use a stock spring even with a set of "Big Tube" headers.I Believe that mine is in the stock location.You just might have to make custom bracket for your application.Good luck to you.
