Clearcoat, newer car
Discussion in 'Detailing Topic' started by Damon23, Sep 6, 2009.
  1. Damon23
    Damon23 Veteran Member
    2,677
    15
    Jan 29, 2006
    Georgia
    My wife has a 04 malibu and that car has been a pain to polish and wax since the day we bought it. Most cars you can apply a wax or polish too and it will go on and come off easy. Well, this car not so much.
    It is black. And whenever I apply anything weather it be a compound, polish or wax I get these marks on it that look like I did'nt remove all the product. Like smears. I can rub and rub and they will not go away, just smear. I was thinking of wet sanding cause maybe it has junk on it, silicone or something like that, that needs to come off first for a good foundation for a shine. There are no low spots, peeling or sun fading. I just think it can look better. I've tried washing with dawn real good then the meguires 3 step system and mostly it looks good but you still see the smear marks. I've also try Zymol after I hit it with 3M perfect-it 2 compound. Anyone have any ideas on the wet sanding idea?
  2. SS2001
    SS2001 Veteran Member
    530
    Jan 4, 2008
    Lithia Springs, GA
    Did you do the clay bar on it?
  3. Damon23
    2,677
    15
    Jan 29, 2006
    Georgia
    Yep. Still the same thing when I wipe the detailer off of it.
  4. 1980z28fromhell
    1980z28fromhell Veteran Member Gold Member
    258
    Sep 20, 2003
    hanford ca
    go to detailcity.org and we will get it straightened out for you ...some of the best detailers in the world there .. im bigron62 there ,,,,
  5. SS2001
    530
    Jan 4, 2008
    Lithia Springs, GA
    I'd be very careful wet sanding. I've got zero experience with it, and if you mess it up it could be a disaster. Sounds like they'll know what to do at detailcity.
  6. TreySmith
    TreySmith Veteran Member
    133
    May 12, 2009
    Pearland, Texas
    I learned how to wet sand at work, it's easy and somewhat fun. You have to be careful though since the paint on newer cars are pretty thin. Just wet sand a little bit to get the crap out and buff it. We use 1500 grit at work, practice on a junker car if you can.
    This is what a little wet sanding will do to the original paint on a 65 Mustang.
  7. ezcruisn71
    ezcruisn71 Veteran Member
    239
    Jun 2, 2006
    SE, Michigan
    I wet sanded my new paint job when I painted my Camaro with PPG Concept paint. For the final step of wet sanding I used 3000 grit DA pad on my DA sander. It is called TRIZAC from 3m. It costs a lot to buy the pads but it is worth it because it saves a lot of time.
  8. Gary S
    20,800
    217
    Your problem might not be the paint. Black is known to be the most difficult color to wax and get it free of streaks and other imperfections caused by the wax. There are a lot of people who would never consider owning a black colored car for that reason. Try talking to other people who have black cars and see what products they are having good luck with. They might be able to help you find an easy way to get the nice finish you want.
  9. tom3
    tom3 Veteran Member
    10,724
    61
    Aug 1, 1999
    ohio
    Had several black vehicles and Gary is spot on. I never hand wax. I use a boat wax, splash it on after a wash, rinse it off and dry. But always have a new clean wash mitt, use only on this car, wash the sides in long horizontal strokes, no circles, lots of soap, wash the sides first, use a different mitt to wash the lower sections where it gets gritty.
  10. MrAzzhat2U
    MrAzzhat2U Veteran Member Lifetime Gold Member
    1,393
    Jan 31, 2000
    Lewes DE
    My method is to wash the car with "Dawn" dish soap and dry thoroughly.Then use a clear coat paint prep,like Maguires,clay bar stubborn spots,then I use Turtle wax "ICE".Seems to work for me.
