Changing Window Felts and Wipes
Discussion in 'Tips 'n' Tricks Topic' started by MartyO, Feb 11, 2015.
  1. MartyO
    MartyO Veteran Member
    290
    Sep 7, 2014
    Hiram, GA
    I am about ready to change them out on my '74.
    Any tips or tricks that anyone can share before I screw it all up?
    Thanks!
  2. MR. FBDY
    MR. FBDY Veteran Member Lifetime Gold Member
    3,907
    May 30, 2001
    hudson, NY
    Is this for the horizontal window felts on the outside of the door?
    If so, take off door panel completely to get to glass stop in bottom of door.
    Loosen the nut and take out the glass stop so you can lower the glass under the window felt to get to all the tiny screws.
    Other than that, it is a pretty easy job.
  3. MartyO
    290
    Sep 7, 2014
    Hiram, GA
    Good deal!
    And what about the interior door panel side of things? How hard is it to swap them?
  4. harbone66
    3,481
    267
    Feb 15, 2011
    Central Illinois
    On the inner sweeps you have to pull all the f'ing staples out that attach them to the top of the door trim panel
    I then drilled 1/8" holes about every 6" and riveted the trim to the panel
  5. MartyO
    290
    Sep 7, 2014
    Hiram, GA
    Great idea!!!
    I like this and will probably do the same!!
  6. gpintauro
    gpintauro Veteran Member
    184
    Jun 4, 2012
    inman,sc
    yep, this is how I did mine.....
  7. MartyO
    290
    Sep 7, 2014
    Hiram, GA
    Come down and do mine and I will have Mizz MO cook ya something!
  8. ChevyReb
    3,784
    Feb 4, 2003
    SC
    So glad I found this thread! I dyed my uppers last night and the replacement felts came with screws :screwup: :screwup: :screwup: I don't think so! I was about to use some flag yard marker rods to emulate the staples but the rivet idea will be wayyyyy quicker. Thanks
  9. MartyO
    290
    Sep 7, 2014
    Hiram, GA
    Good deal!
  10. ChevyReb
    3,784
    Feb 4, 2003
    SC
    Well I need to get some rivets that have a longer grip length because 1/8x1/8 were not long enough. Did you guys use 1/8x3/16# 43 rivets or something else. The heads in the pics look like larger diameter than 1/8?
