Changing motor mounts
Discussion in 'Tips 'n' Tricks Topic' started by 79silverz28, Mar 14, 2006.
  1. schitzo
    schitzo Veteran Member
    1,300
    Feb 12, 2005
    Minneapolis MN
    I don't have what you need but I am in the same situation. I am swappin a ls1/t56 in my 71 and have to move the mounts on the K member back a few inches.
    It was very easy removing the nuts and bolts but I wonder how hard it will be reistalling them in their new positions.
    I used a 9/16'' distributor wrench and regular wrench with a 9/16 " socket to remove the bolts closest to the rad on each side as well as the lower most bolt.
    the distributor wrench would not work with the top bolt and nut closest to the firewall.......I found out that a regular socket and extention will go directly to the nut in the crossmember. it took me less than 30 mins to remove them all
    I have to drill new holes further back in the X member.I plan to use the Dist wrench with duct tape on the bottom to hold the nut in place while I insert the bolt from up top
    This thread saved me alot of work.....I was going to remove all the front suspension.
  2. OldSchoolFormula
    OldSchoolFormula Veteran Member
    110
    May 26, 2004
    Livermore
    Yep, but my main problem is I have Pontiac frame mounts. The junkyards around here are all a few feet deep in mud at the moment... :(
  3. schitzo
    1,300
    Feb 12, 2005
    Minneapolis MN
    def try eBay.....they should be easy to find
  4. OldSchoolFormula
    110
    May 26, 2004
    Livermore
    Youd think so, but havent seen a single pair yet. Lots of BBC mounts, though.
  5. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,015
    45
    Feb 2, 2008
    SF
    i have that problem too. i have pontiac frame
  6. Vicious Z28
    Vicious Z28 Veteran Member
    113
    Mar 3, 2007
    Upper Marlboro MD
    Yeah the nut has a flanged side like a built in washer. This holds the nut in the dizzy wrench.
  7. Twisted_Metal
    25,613
    383
    I pulled the bolts up though the frame/mount and put the nuts/washers on top.
    It only took about 20 minutes to take the wrong mounts out and put the right ones in while my engine installation team took a beer break. ;)
  8. bbc nova
    bbc nova Veteran Member
    1,124
    Apr 18, 2007
    MN
    Thats no shiznit!!!!!!! I cant believe he changed them so fast.:eek:
  9. 68400BIRD
    68400BIRD Veteran Member
    2,950
    9
    Feb 7, 2006
    GO PACK GO
    Well, he did do it three different times.:p
  10. Twisted_Metal
    25,613
    383
    Three times over a 15 year period.
    The last time was by far the fastest.
    (Thanks again, Rob, for finding the bolts I lost in the frame. :) )
