cdf 207 blocks
Discussion in 'Engine Topic' started by arty, Dec 20, 2017.
  1. arty
    arty New Member
    Dec 20, 2017
    • is this a 400 engine block and it only has 2 freeze plugs on the sides.making a 383 and hear the 400 block is best.if so what is the number on that block. thank you all for helping this old man.
  2. CorkyE
    9,206
    214
    Here's the only thing I found on Mortec with that number; 14010207...350...80-85...2 or 4. So if that's correct, you have a 350 block, used from 1980 to 1985, with either 2 or 4 bolt mains. The most common combination to reach 383 cid is a 350 (4") bore with a 400 (3.75") crank. Using a 400 block and 350 crank will yield 377 cid.
    Welcome to Nasty Z.
  3. arty
    arty New Member
    Dec 20, 2017
    which would i get more hp from ,350 with 400 crank or a 400 with 400 crank bought stroked.202 heads, cam and such.what is each cu.in. and hp of each.
  4. CorkyE
    9,206
    214
    No replacement for displacement...
  5. Lowend
    14,301
    235
    Mar 25, 1999
    San Jose, CA, USA
    Gonna need a whole lot more information here to advise.
    Can you talk about goals for the car and what you have already?
