Carburetor back fire
Discussion in 'Troubleshooting & Diagnosis' started by Justin79maro, Apr 10, 2017.
  1. Justin79maro
    Justin79maro Veteran Member
    102
    Jan 15, 2015
    Bonne terre, missouri
    So fellas, my camaro was running the best it ever has and on Friday night leaving the track unnoticed it started to act funny. I noticed around 2500rpm it would sound like a spark knock but it was a different kind of noise. Now it back fires out the carburetor, but it's not a flame it's just raw gas that comes back out when you rev it up and when you turn it off. Since it randomly started doing it I checked the timing and played with it some but that has no effect, I even messed with the Axel pump on the carb and that does nothing either. I even pulled the valve covers off and checked the rockers but it all seems good... anyone have an idea?
  2. Bandit723
    Bandit723 Veteran Member
    2,329
    273
    Oct 1, 2016
    Waupaca WI
    Timing chain may have jumped...
  3. Justin79maro
    102
    Jan 15, 2015
    Even with a engine that's got less then 6,000 miles on it?
  4. CorkyE
    9,203
    214
    Broken valve spring? And like Bandit says, could be timing chain. You said you checked timing - what's your initial & total timing?
  5. CorkyE
    9,203
    214
    It's not common but it can happen, it's mechanical...
  6. jimrr
    jimrr Veteran Member
    1,033
    226
    Jun 12, 2016
    sarasota
    Holley carburetor? Power valve blown.....
  7. Justin79maro
    102
    Jan 15, 2015
    Quick fuel slayer 750 I guess I'll try a power valve..
  8. Justin79maro
    102
    Jan 15, 2015
    Initial is 14* as of how it sets right now. I'm not sure on the total
  9. Justin79maro
    102
    Jan 15, 2015
    I can't get a reading on it because the light goes out which means number 1 isn't firing.. hmmm
  10. 80sz
    80sz Veteran Member
    2,361
    206
    Feb 2, 2014
    Buffalo,n.y.
    Swap out a good plug wire on 1 . Might have a burn in it grounding it out?
