Camaro weights
Discussion in 'High Performance Modifications' started by Plant Engineer, Oct 26, 2017.
  1. Plant Engineer
    Plant Engineer Veteran Member
    346
    72
    May 17, 2017
    Washington State
    I had a brand new scale installed at work. Certified yesterday. Here are the weights for a dart block BBC Camaro set up like a '70 with aluminum heads and intake, TH 400 transmission and a Dana 60, 10 point cage , 4 wheel disk brakes and 220 lb driver and 4 gallons of gas in the tank. All steel body , interior with no back seat, steel tubs etc. Weights are with me in it as I needed weights for chassis setup. Turns out they were right where I wanted them to be.
    Overall 3630
    Front Axle 2030
    Rear axle 1610
    Front right 1020
    Front left 1050
    Rear left 790
    Rear right 790
    I will note that this weight came as a surprise to me. I had it weighed at a local truck scale previously and it came in at 3500 lbs without driver and have since changed blocks to the Dart Big M which is considerably heavier than a factory 454 block. I expected it to be around 3580 but it came in at around 3410 lbs without driver. The first scale was wrong by a wide margin.
  2. Turbo70Camaro
    2,129
    111
    Jan 7, 2005
    so cal
    dang ill probably be close if not more then that o well just turn the boost up I guess ;)
    Plant Engineer likes this.
