Camaro 1975 454 6-speed from Finland
Discussion in 'Project Progress' started by pecu_83, Feb 23, 2016.
  1. pecu_83
    pecu_83 Veteran Member
    122
    Feb 22, 2016
    Finland
    I roughly pulled out the big dents with a pull hammer
    The roof was so badly damaged, I cut a part off and made a new one from sheet metal, but I couldn´t find pics.
  2. pecu_83
    122
    Feb 22, 2016
    Finland
    The rear bumper was so heavy, I decided to do the rear end out of sheet metal
    I then put on some rust preventing primer and filler on the bare spots so it wouldn ´t rust in the cold, moist garage it was in.
  3. pecu_83
    122
    Feb 22, 2016
    Finland
    Here is the engine and the TH-400 that came with it. Even though it was junk, these big blocks are really expensive here in Finland. This motor didn´t turn all the way over (the seller told me on the phone it would) and I still had to pay 900€ for it and it was still by far the cheapest big block I could find.
    One cylinder had had water in it and was corroded pretty bad.
    After some honing it still looked bad
  4. pecu_83
    122
    Feb 22, 2016
    Finland
    I had the block bored and started the assembly with new bearings
    Crank
    Powerforged pistons
    New more agressive cam (still flat tappet tough)
    Ready to install heads
    Heads on
  5. pecu_83
    122
    Feb 22, 2016
    Finland
    I was going to use roller rockers, but the Procomp heads are so poor quality the studs werent aligned properly, so i had to change to roller tip rockers.
    It was quite a job to get the valvetrain working correctly. I had to modify the guideplates to get enough adjustment in.
    And my tools were crap! :D
  6. pecu_83
    122
    Feb 22, 2016
    Finland
    New stronger timing chain
    I had to modify the timing chain cover because the new chain was thicker
  7. pecu_83
    122
    Feb 22, 2016
    Finland
    RPM airgap on
    Magnet to oil pan to collect inpurities:
    Oilpan and valvecovers on
  8. pecu_83
    122
    Feb 22, 2016
    Finland
    Since the 454 is externally balanced and there were no flywheels with the correct balance, I ordered an external balancer plate. I had to modify it a bit to make it fit
    Waterpump and damper installed
    Accessories
    I later found out I had to move the accessories a bit more to fit the enginebay
  9. pecu_83
    122
    Feb 22, 2016
    Finland
    I bought some old racing seats for the Camaro
    They were dirty as hell so I tore them apart and washed them
  10. pecu_83
    122
    Feb 22, 2016
    Finland
    I put the engine to a test stand so I could run the cam in and see if there were any major problems
    Here is the video of the very first startup:
    [youtube]1oUO_KWXlPw[/youtube]
