Camaro 1975 454 6-speed from Finland
Discussion in 'Project Progress' started by pecu_83, Feb 23, 2016.
  1. pecu_83
    pecu_83 Veteran Member
    123
    Feb 22, 2016
    Finland
    Haha!:D
    Actually that didn't come out that well, unless you mean't "Nice (the city in Italy) you have had an explosion drive class" but thank you so much for trying! I think I understand what you tried to say though ;) it was a blast!
    Bandit723 likes this.
  2. pecu_83
    123
    Feb 22, 2016
    Finland
    I look busy because we have turns in both directions;) :D
  3. xten
    xten Veteran Member
    1,019
    419
    Sep 24, 2014
    Pittsburgh, Pa.
    Excellent job!
  4. pecu_83
    123
    Feb 22, 2016
    Finland
    Got some new wheels to get the old look back :cool:
  5. pecu_83
    123
    Feb 22, 2016
    Finland
    Yesterday I made a quick base for the new front wing. It´s only plate at the moment, but I´ll add some winglets in front of the tires and some aluminium profile for rigidy later. It´s a bit wider than the old one and a bit more to the front. I also put on some highlight tape on the wheels, I think it adds a nice flavour to the car. :)
  6. Zspoiler
    Zspoiler Veteran Member
    2,024
    100
    May 6, 2012
    Federal Way, Washington
    On the Fibermotive IMSA rear wing I was looking at it bolted to the trunk floor .Maybe its stronger that way. And continue to have all sorts of fun.
  7. pecu_83
    123
    Feb 22, 2016
    Finland
    Been a busy week. Last tuesday I started to prep my car for wednesdays track day. The alternator had stopped working (I guess rallycrossing). Had to buy a new one. I finished the wing, changed oil, unbent the skidplate etc. Then I went for our local monthly meet. On the way there, the clutch cable snapped. I had to shift without cluth the rest of the way to the meet, from there to parts store where they didn´t have a cable, from there to my dads only to find a broken cable and from there to home. I ended up welding a new thread piece on the end to make it work for next day.
    At the meet
    Next day was track day:
    Radalta:
    Then I broke my engine. I ran it too hot and under hard braking I think the oil pressure dropped and when I went back on the gas it started a really bad rod knock after two corners. I towed the car home and saturday I tore it apart.
    Pressure wash
    7cyl rod bearing
    Now I´m looking for new crank and rods. Not so easy to find here in Finland or expensive.
  8. Bandit723
    Bandit723 Veteran Member
    2,260
    262
    Oct 1, 2016
    Waupaca WI
    Boy sounds like a rough week. Nice job on the spoiler by the way. Feel your pain on the broke engine just went thru a rebuild not too long ago.
  9. Zspoiler
    2,024
    100
    May 6, 2012
    What a bad week.Are you going to change to a road race oil pan or a dry sump with an oil cooler so it won`t happen again. I hope things get better for you.
  10. pecu_83
    123
    Feb 22, 2016
    Finland
    Thanks guys.
    I think I´m going to modify the stock pan and add an oil cooler and ran a bit more oil at a bit higher level. And go back to Valvoline Racing 10W60 oil which I had no problems with last summer, expect it leaked a bit, but I got a handle on it this spring.
    Here´s a GoPro video from the track with GPS-laptimer-data overlay:
