C5 Front Hubs
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Jerry SS 396, Dec 6, 2015.
  1. Jerry SS 396
    Jerry SS 396 Veteran Member
    236
    Nov 2, 2008
    NORTH JERSEY
    I'm in the market for c5 front brakes with the C5 style hubs. I can go with the CPP spindle with ZR1 hubs. But have read some negativity about the CPP brand products. Can the AFX spindle be used with a GM lower with delrin bushings and aftermarket tube type upper and tall ball joint ? I have 18x9 wheels.
  2. gray86hatch
    gray86hatch Member
    74
    May 31, 2012
    battle creek mi
    Kore3.
    Mine have been perfect
    Tim
  3. BonzoHansen
    Why do you need c5 bearing packs?
    By AFX you mean the speedtech spindles? If so you should call them.
  4. badazz81z28
    15,273
    216
    Las Vegas, NV
    Right here. If you want C5 brakes, they sell a good kit. If you want something more aggressive like 6 piston calipers, 14" rotors etc. look at the names like Baer and Wilwood as they will have a price competitive kit over Z06
  5. 71RS/SS396
    71RS/SS396 Veteran Member
    2,608
    23
    Aug 26, 2008
    Wake Forest NC
    Don't buy the ZR1 hubs, the C7 hubs bolt right on, have a larger bearing and thicker wheel mounting flange, and cost about $120 each vs the $400+ the ZR1 hubs cost. Gm part# 20981829. I just replaced the C5/6 bearing on my wife's car with a DSE subframe and they bolted right on.
  6. V8240Z
    V8240Z Member
    58
    May 23, 2011
    SAN DIEGO, CA
    The CPP uprights are fine, it's the garbage hubs and brakes that are the problem. After having one come apart, they asked me ' You're not autocrossing with these are you?' It cost me another $1200 to make them work correctly. CPP's answer was to supposedly put a disclaimer in their printed catalog.....
  7. BonzoHansen
    new vettes are still 5x4.75 bolt pattern?
  8. Lowend
    14,668
    340
    Mar 25, 1999
    San Jose, CA, USA
    Yep - it's the only car left. GM has some strange point of pride with that bolt pattern and Vette's
  9. 71RS/SS396
    2,608
    23
    Aug 26, 2008
    Wake Forest NC
    Yes they are.
  10. Jerry SS 396
    236
    Nov 2, 2008
    NORTH JERSEY
