bulb socket schmooo
Discussion in 'Electrical Systems' started by phat80, Feb 14, 2018.
  1. phat80
    phat80 Veteran Member
    1,019
    9
    Jan 4, 2013
    Victoria BC
    I'm at the point where I'm cleaning up my original (1980) rear wire harness. As I was cleaning the bulb holder sockets I found them to be caked with a beige, thick mastic type of material which I scraped out.
    My guess is the schmoo was packed in there at the factory to act a water seal/ vapor barrier. Do any of you kids have a suggestion for a workable replacement?
    I thought of smearing some dielectric grease in there but I don't think that's really the best product for the job.
  2. Da_Raabi
    Da_Raabi Veteran Member
    1,062
    126
    Jan 19, 2011
    Daytona Beach, FL
    I'm not sure what that stuff is. I noticed it when I was at that point with my harness too. I just left it alone in mine, but I did notice that it seemed to make the bulbs a little more difficult to get in and out.
    I'd be curious if new sockets would use that stuff too?
  3. Twisted_Metal
    25,750
    443
    That's factory stuff.
    I believe it was intended to be a moisture seal but it does eventually shrink a bit and may not work well if your car is exposed to natural elements.
    Clean it all out, clean the electrical contacts within the bulb holder and use a little di-electric grease to aid as a corrosion preventative measure when you reassemble.
    Cardinal likes this.
  4. ol' grouch
    ol' grouch Veteran Member
    1,575
    338
    Jul 4, 2013
    Evansville, In.
    Dielectric grease is what I use. I've done it for decades and it works just fine. It isn't a conductor by itself but promotes it between contacts as well as weather proofing the connection and making putting it together and taking it apart easier.
  5. phat80
    1,019
    9
    Jan 4, 2013
    Victoria BC
