Budget air compressor
Discussion in 'Garages, Workshops & Tools' started by sooner, Aug 7, 2009.
  1. sooner
    sooner Veteran Member Lifetime Gold Member
    1,414
    Mar 11, 2009
    Perry,Ok
    Im in dire need of an air compressor, but on a pretty tight budget so im looking for a good value/ good quality air compressor. Any ideas on compressors under say $300? Thanks in advance. btw, can be either 120 or 240v
  2. Cardinal
    8,245
    13
    Jun 22, 2003
    Endicott, NY
    Most of the "inexpensive" air compressors under $300 with enough volume to run air tools are going to be oil less. They are noisy and aren't meant to last a lifetime but will be OK for the average weekend mechanic.
  3. Marks71BB
    What do you intend to use it for?
    Did you want to get new or would a used one be ok with you?
  4. sooner
    1,414
    Mar 11, 2009
    Perry,Ok
    I would be fine with a used one. I really just want to get the best one I can get for as cheap as I can get it.
    Im just going to use it mostly for weekend projects, but I would like for it to be able to keep up with a die grinder, dynafile, or 90* grinder/cutoff if possible. is that asking a little too much for a cheap compressor?
  5. sooner
    1,414
    Mar 11, 2009
    Perry,Ok
  6. buckeye79
    buckeye79 Veteran Member Lifetime Gold Member
    636
    Dec 16, 2007
    Crestline, Ohio
    I don't have any experience with Puma compressors other than you can buy them at harbor freight.
  7. Gary S
    21,271
    359
    Unless you buy a good expensive die grinder, it won't run on any 110v compressor. The cheap die grinders are such air hogs that they need at least a 220v compressor to get above 10cfm, and preferably more.
  8. Mr.SS
    Mr.SS Veteran Member Gold Member
    660
    Aug 10, 2006
    NS.
    I have a nice Husky 8hp that runs all of my tools with no trouble. It runs on 220 and has served me well in moderate use (not full time) for about 5 years with zero problems. We bought it at the Home Depot for about $700 here but I bet it would be half that in the US.
  9. MEAN79
    MEAN79 Veteran Member
    282
    Mar 26, 2009
    Manhattan, Kansas
    DON'T i repeat DON'T buy Harbor Freights air compressors. my step dad has a 60 gallon that he bought form them. and it is loud vibrates like crazy. and the pump started leaking a year after he got it. He still uses it when he needs to but regrets ever buying it.
  10. 76_TypeLT
    6,392
    136
    Jul 26, 2008
    Houston, TX
    I researched air compressors and from what I read Puma is in the same league as CH and IR compressors. I was going to suggest looking on CL because I bet you will find some nice deals if you are patient enough.
