Brakes on 80 Z28
Discussion in 'Troubleshooting & Diagnosis' started by JD Z, Aug 28, 2017.
  1. JD Z
    JD Z Veteran Member
    Ive driven only a few times. I noticed when pressing the brake it makes a sound of hearing the fluid gushing/pushing through when the rake is pressed. The brakes work, though not as good as I would expect and nothing is leaking. Is this something obviously needing attention with the brakes? Seems it might signify air in the lines or something simple.
  2. CorkyE
    9,043
    170
    Sounds like a bad diaphragm in the brake booster. Not a fun job but it's doable with some patience and a swivel head ratchet wrench.
    JD Z likes this.
  3. JD Z
    JD Z Veteran Member
    Thanks CorkyE. You think the GM dealer will take me for a ride if I bring it in for service? It's been 30 years since I've played as a mechanic...I have tools still, but the office world has made me a little soft I guess. One day I hope to get that grease feeling back!
  4. CorkyE
    9,043
    170
    Any trustworthy local repair shops in your area?
  5. JD Z
    JD Z Veteran Member
    I'm trying to figure that out and I have one suggestion on a local repair shop.
