Brake
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by JD Z, Oct 22, 2017.
  1. JD Z
    JD Z Veteran Member
    Brake pads and calipers are nearly new and checked at the shop recently. The master cylinder and booster just replaced. Brakes work good, but there is a pull to the right with the first brake press. The second and third don't have a pull. Drive some more and the first brake press has a pull. I'm taking it back in this week to check on this. Any experience with what may be causing it?
  2. BonzoHansen
    Hoses or bad caliper are likely culprits
    JD Z likes this.
  3. JD Z
    JD Z Veteran Member
    Hoses it was. The shop just replaced them after some tests and that did it.
