bottom floor pan?
Discussion in 'Body Restoration' started by tims78camaro, Nov 1, 2017.
  1. tims78camaro
    tims78camaro Veteran Member
    558
    Aug 6, 2008
    louisville ky
    getting ready to put my floor pan in to weld it. its scratch on the bottom from fitting it. should i just put self etch primer on it or what should i use? and what should i put on there before undercoating goes on?
  2. HawkX66
    HawkX66 Member
    84
    22
    Sep 20, 2017
    MI/MA
    You should strip the EDP coating off it and shoot it with epoxy primer. I sprayed my 69s pan with SEM Trim Black over the epoxy and it's pretty durable. I don't see a reason for undercoating a car unless you're driving in the salt or down seriously bad dirt roads. Even that's debatable. I live on a dirt road and have to drive for 3/4 mile to get to pavement. No problems other than dust.
  3. CamarosRus
    CamarosRus Veteran Member
    20170903_153149.jpg imagejpeg_0.jpg imagejpeg_0001002003.jpg imagejpeg_0001002003004.jpg output.jpg Buy SPI (Southern PolyUrethane) primer directly from SPI (Google)
    and have shipped TO YOUR DOOR......
    Use UPOL Raptor in Wheelhouse area OR on complete underfloor
    You can leave Underfloor in SPI primer or Top Coat
    with PPG Delfleet Essential Black (use DX10 to make Semi or Satin gloss)
