Body Bushings Replacement: How to with tips
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by sandiego74, Oct 27, 2012.
  1. sandiego74
    sandiego74 Veteran Member Lifetime Gold Member
    1,044
    40
    Feb 23, 2009
    San Diego, CA
    It's been so long that I don't exactly remember. Are they all different sizes? I thought I remember them being all the same.
  2. Overtrained
    Overtrained Veteran Member
    191
    Sep 10, 2015
    Merrick, NY
    Follow the numbers stamped into the bushing according to the diagram they give you. The smallest ones are the front radiator support. Piece the parts together on workbench, it looks confusing at first but it will click.
  3. Tpichevy
    Tpichevy Veteran Member
    447
    14
    Jun 21, 2016
    Boise id
    Great thread. Subbed so I can look back as I'm about to start my solid swap soon
  4. tbrostrom
    tbrostrom Member
    87
    Feb 11, 2015
    Portland, NY
    Just got done replacing my subframe bushings. Thanks to instructions from this thread the job is relatively easy. Fortunately the underneath of my car is in great shape, but really do yourself a favor and soak the bolts with PB Blaster for at least a week and the bolts should come out very nicely!!
  5. z28code
    z28code Member
    50
    May 4, 2008
    ont
    any one confirm or deny that solid body mounts will crack body seams over time ect?
  6. 70lt1z28
    2,474
    365
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Even with the PB (good stuff) I still had to heat one of the caged nuts with a propane torch to loosen it up. I heated it, then hit with a blast of PB and you could see the PB get sucked in. It came lose really easy then. Don't break the cage. It will make the job much more difficult.
  7. Zstar
    Zstar Veteran Member
    1,380
    286
    Mar 23, 2014
    Ocala, Florida
    I did not have a problem with the bolts as much as the donut rubbers had welded themselves to the subframe and body. THAT was fun.
  8. sandiego74
    1,044
    40
    Feb 23, 2009
    San Diego, CA
    I haven't had any problems as of yet.
    z28code likes this.
  9. Bandittransam
    Bandittransam New Member
    Sep 20, 2017
    Any possibility of reposting those pics. Looks like the pictures are no longer visible due to the way photobucket has change their hosting and now charges
  10. 70lt1z28
    2,474
    365
    Oct 3, 1999
    If you are using Chrome or Firefox as your browser there is a add-in available to fix the Photobucket issue. Seems to work pretty good for now, but it may not last as PB will probably try to break it
