body bushing squeak over bumps? coil springs?
Discussion in '1970 - 1973 Specific' started by dhunter93, Jul 9, 2017.
  1. dhunter93
    dhunter93 New Member
    22
    Sep 6, 2012
    CA
    Anyone encounter a front end squeak from body bushings or coil springs? I rebuilt the front end hoping to get rid of the noise yet the squeak continues.
  2. Twisted_Metal
    25,616
    383
    Don't know what it sounds like but you can usually narrow down the source of the squeak by raising the hood and bouncing the car while someone else follows the noise.
    Do you have polyurethane bushings in the control arms?
    Check for contact with the upper shock absorber washers too.
  3. dhunter93
    22
    Sep 6, 2012
    CA
    Rubber not poly, will not squeak unless under load moving down the road.
    Just asking if anyone has had a squeak coming out of body bushings or coil spring.
  4. Green hornet
    Green hornet Veteran Member
    1,185
    159
    Oct 11, 2015
    North Bay, CA
    I just read a post the other day about lubing the hood bumper stops. The bad squeak I had went away after doing that. Give that a try.
  5. dhunter93
    22
    Sep 6, 2012
    CA
    Stange but worth a shot !
  6. biendog
    biendog Veteran Member
    155
    9
    Oct 8, 2011
    bellville,tx
    I was gonna suggest just that,my car had a squeak too and I traced it there,problem solved.
  7. berg2695
    berg2695 Veteran Member
    162
    16
    Nov 13, 2011
    Auburn, WA
    +1 on the hood bumpers. On my car the one at the back near the center was usually the culprit. Also, the rubber bumpers that support the bottom edge of the windshield have been known to squeak. I don't know if they really need to be on there after the windshield is installed. Maybe someone on here knows for sure.
  8. 70 SS/L78
    2,400
    42
    May 5, 2005
    Rockford, MN
    The windshield supports need to be there! Without them your windshield will gradually slide down, especially when sitting in the hot sun.
  9. dhunter93
    22
    Sep 6, 2012
    CA
    It was the body and core support bushings, However, Thanks for the input!
  10. Green hornet
    1,185
    159
    Oct 11, 2015
    North Bay, CA
    Good to hear your figured it out.
