Body Bushing Installation Tip
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Twisted_Metal, Aug 12, 2005.
  1. russelljones48
    russelljones48 Member
    32
    Dec 23, 2015
    mooresville nc
    subframe bushings
    Any chance you could re-post those PICS from your dialog on replacing the bushings?
  2. Twisted_Metal
    26,298
    614
    Those pics were lost in a hard drive crash several years ago. :(
    There's a much better write-up here. --> http://www.nastyz28.com/forum/showthread.php?t=251412
  3. russelljones48
    32
    Dec 23, 2015
    mooresville nc
    TM: thanks. nice detailed thread. Not sure how I missed it???
  4. willem
    willem Veteran Member
    127
    Nov 6, 2017
    is there another bb write up with pics?
  5. Jeff L - 1970 Camaro Z28
    Jeff L - 1970 Camaro Z28 New Member
    10
    Nov 14, 2017
    I'm very interested in learning more about the sub frame alignment holes - where are they, what size bolts are used, are nuts required. If anyone has detailed information on checking the alignment, I would appreciate. I've often suspected my SF is misaligned, based on the different fender shims required left to right, but wasn't sure how to go about confirming this. Also, I see some rebuilders completely removing the SF for blasting and painting. I've always been concerned that proper alignment could not be re-established. How accurate are these alignment holes and has anyone run into trouble re-installing there SF.
  6. willem
    127
    Nov 6, 2017
  7. Twisted_Metal
    26,298
    614
    The alignment holes are next to the subframe mounts under the firewall (middle set of mounts).
    5/8" diameter bolts, no nuts.
    You can thread the old sub frame bolts (if they aren't too rotted away) through the alignment hole and into the body. If everything is aligned correctly, there isn't much play there.
  8. willem
    127
    Nov 6, 2017
  9. 70-camaro
    70-camaro Veteran Member
    1,943
    323
    Mar 25, 2010
    marietta ohio
    AFF2AB1B-4974-4D46-B3FE-52DE9486259D.jpeg 0E37413C-9CD2-4417-9016-A7F6DC8D7529.jpeg Here are a couple of pics of alignment holes.
  10. Pioneer77
    Pioneer77 New Member
    Jun 9, 2018
    I have the same problem on my car. What did you use to cut off the bolt head?
