Body Bushing Installation Tip
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Twisted_Metal, Aug 12, 2005.
  1. badazz81z28
    15,249
    215
    Las Vegas, NV
  2. cubangt
    cubangt Veteran Member Lifetime Gold Member
    2,268
    Jul 5, 2010
    Katy, Tx
    well hopefully it will be simple enough to figure out tonight, atleast I know that the driver side one in the posted pic is correct based on the steps, the front firewall steps are suppose to be the long ones..
  3. cubangt
    2,268
    Jul 5, 2010
    Katy, Tx
    Well it was a simple 10 minute job to swap out the bolts and retorque.
    Body mounts are checked off list.
  4. rocket dawg
    rocket dawg Veteran Member
    260
    14
    May 5, 2015
    Grand Rapids Mi
    I like this thread but some of the original pictures expired or dont show up. Do I need to download a different program to see them or are they just outdated?
  5. Twisted_Metal
    26,218
    582
  6. rocket dawg
    260
    14
    May 5, 2015
    Grand Rapids Mi
    Thats exactly what i was looking for. thank you very much.
    I have the bolts already soaking in PB Blaster for about a week now.
    Mine will be slightly different in the front part ( I have a 79 Trans Am 406 sbc)
    But I can see the front nuts thru the front air openings which should make this job quite a bit easier, I hope.
  7. rocket dawg
    260
    14
    May 5, 2015
    Grand Rapids Mi
    I have 4 of the 6 loose. The firewall bolts are soaking for a few more days.
    One quick question: I have the rear bolts loosened, the large washer and rubber are rust welded to the bolts and dont fit out the opening of the frame Whats the answer for that?
    thanks for a great site.
    randy
  8. cubangt
    2,268
    Jul 5, 2010
    Katy, Tx
    There is a post that shows you how to gently lift the body up using a 2x4 / 2x6 and floor jack to give you a few inches of clearance.. if you cant break loose after a little lift, may have to go another route on removing..
  9. rocket dawg
    260
    14
    May 5, 2015
    Grand Rapids Mi
    Thanks, that makes sense to me now. Once the body is up it will slide out the slot.
  10. rocket dawg
    260
    14
    May 5, 2015
    Grand Rapids Mi
    5 of the 6 loose, drivers side firewall position isn't giving it up yet. More PB today!
