Blower Resistor?
Discussion in 'Electrical Systems' started by 79supergasdriver, Dec 28, 2017.
  1. 79supergasdriver
    79supergasdriver A Scholar and a Gentleman
    756
    Jun 22, 2005
    Wichita, KS, USA
    See attached images, please. Is this thing the blower resistor? It was in the top of the old AC box which I changed out for a smooth fiberglass non-AC box. Looks like one coil has broken. Can I cut a hole in the top of the new box and drop (a replacement for) this thing in, or does it need to be in a specific place/orientation, or can I omit it altogether since I'm not installing the AC system? 20171228_173758.jpg 20171228_173818.jpg
  2. Gary S
    21,076
    305
    You need the resistor if you want multiple fan speeds. For A/C systems it is mounted inside the box, probably to get air flow to help cool it. For non-A/C systems it is in the heater control in the dash usually. A/C systems use a larger fan motor to move enough air to handle the air conditioning so cooling for the resistor is more important.
  3. ol' grouch
    ol' grouch Veteran Member
    1,575
    338
    Jul 4, 2013
    Evansville, In.
    GM put the resistor block in several places. They always have air flow over them to keep the wire coils cool. Default is full speed on the fan. the resistor block cuts the voltage back through resistance to slow the fan speed down.
  4. Rdobbs1977
    Rdobbs1977 Huge Guns N Roses Fan
    283
    10
    Dec 1, 2014
    Nashville
    i wouldn't run a resistor on a non ac car. i put one in mine a few years ago but need to take out. reason being, 'old car 3 speed fans' don't run like you'd expect in newer cars. if i'm running heat in the old car, chances are i'm running on high at all times. jmo
  5. hogg
    hogg Veteran Member
    3,143
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    They can be bought on ebay for less than $15,maybe 10. that do same job.
  6. NOT A TA
    NOT A TA Veteran Member
    189
    46
    Feb 12, 2009
    Delray Beach Florida
    I removed under hood AC and installed a standard heater box. I mounted the resistor in the heater box as shown in pic below. Ran it that way for many years with no issues.
  7. 79supergasdriver
    756
    Jun 22, 2005
    Wichita, KS, USA
    I think that's what I'm going to do as well just to minimize the pain of figuring out wiring to make things work. 18839436_1731890603493272_7182406981027059042_o.jpg
