bilstein rear shock too short ?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by need-for-speed, Mar 8, 2014.
  1. need-for-speed
    need-for-speed Veteran Member
    655
    Feb 7, 2003
    Conroe, TX
    I am replacing the shocks on my '79 Camaro with Bilsteins. Fronts fit just right. The rears (pn 24-001564) seem to be too short. I have top bolted in. There is a gap (about 1/4 - 1/2 in) between the rubber bushing at the bottom and the top of the mounting pad. Do I just use the lower nut to "pull" it down ?
  2. need-for-speed
    655
    Feb 7, 2003
    Conroe, TX
    Well evidently snugging it down doesn't work. It closed the gap - by pulling the car down on its suspension. No good.
    I can't believe this is the wrong part ??
  3. sbca96
    sbca96 Veteran Member
    2,887
    Oct 25, 2004
    Santa Barbara, Ca
  4. Todd80Z28
    11,165
    97
    Jun 11, 2002
    Northern VA
    Yes.
    Don't draw it up with the shock nut- that's a recipe for thread galling. Instead, jack up slightly on the axle until the pads are seated, then tighten.
  5. need-for-speed
    655
    Feb 7, 2003
    Conroe, TX
  6. need-for-speed
    655
    Feb 7, 2003
    Conroe, TX
    Thanks Todd. The suspension was fully loaded.
  7. sbca96
    2,887
    Oct 25, 2004
    Santa Barbara, Ca
    So the suspension is at "rest" and the shock is too short?
    Something is most definitely wrong then. When I google "pn 24-001564" :
    http://www.summitracing.com/parts/bsn-24-001564
    Bilstein 24-001564 - Bilstein B6 HD Shocks and Struts
    Shock, B6 HD, Monotube, Rear, Chevy, Pontiac, Each
    Year
    1981 (10)
    1980 (10)
    1979 (10)
    1978 (10)
    1977 (12)
    1976 (12)
    1975 (10)
    1974 (10)
    1973 (10)
    1972 (12)
    1971 (10)
    1970 (10)
    Make: CHEVROLET
    Model: CAMARO
    Beginning Year: 1970
    Ending Year: 1981
    Drivetrain: RWD
    Ride Height (application): Stock
    Amount Raised: None
    Amount Lowered: None
    Shock Position: Rear
    Make: PONTIAC
    Model: FIREBIRD
    Ending Year: 1981
    Drivetrain: RWD
    Amount Raised: None
    Tom
  8. Todd80Z28
    11,165
    97
    Jun 11, 2002
    Northern VA
  9. GoldenOne7710
    GoldenOne7710 Irrelevant Member Lifetime Gold Member
    4,521
    287
    Jun 23, 2004
    Athens, GA
    We need a picture of what you're seeing. Have you ever replaced the leaf springs or had them out?
  10. need-for-speed
    655
    Feb 7, 2003
    Conroe, TX
    Thanks to all for the replies. Unfortunately, I didn't think to take any pics when the Bilstein was installed. The bilstein measures about 1-11/32 inch shorter than the old shock that I pulled out. I did change the springs back in 1992. That's about the same time I installed the Sears gas shocks that I just pulled out. The Sears shock length was just right. The ride height of the car is right. The rear end isn't too high.
    With the old Sears shock, the upper rubber bushing on the bottom of the shock just made contact with the top of the shock mount. The Bilstein had a gap between that bushing and the mount. I was just barely able to get enough of the threaded rod through the hole to get a nut started. The new shock measures 22-7/8 in long when measured as shown.
