big block factory rocker arm ratio
Discussion in 'Engine Topic' started by nuhmizer, Aug 25, 2007.
  1. nuhmizer
    nuhmizer Veteran Member
    561
    May 18, 2006
    San Diego, CA
    Does anyone know what the stock rocker arm ratio is for a 454? I looked for a set on summitracing.com and they're all 1.7 and a few 1.8's. I though it was 1.5 but is that sbc?
  2. BlownBigBlock
    BlownBigBlock Veteran Member Lifetime Gold Member
    3,878
    Mar 2, 2000
    Carlisle PA
  3. Damon
    Damon Veteran Member
    12,937
    21
    Nov 16, 2000
    Philly area
    Yeah, 1.7 is stock for a big block.
  4. nuhmizer
    561
    May 18, 2006
    San Diego, CA
    So if I bought roller tips that were 1.72 ratio, would that drastically change the lift? I have a 560 lift edelbrock cam, stock valve springs.
  5. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    do the math.
    560 divided by 1.7=cam lift. Cam lift times 1.72 = new valve lift.
  6. nuhmizer
    561
    May 18, 2006
    San Diego, CA
    566.58.
    Is that too much for stock valve springs
  7. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    Depends if they're singles or duals and they're open/closed pressures.
  8. nuhmizer
    561
    May 18, 2006
    San Diego, CA
    singles. I dont know what open/closed pressures is. They are just stock valve springs
  9. rustbucket79
    rustbucket79 Veteran Member
    .560 plus stock bbc valve springs equals spring bind/cam death. All the factory springs had far too much spring rate, giving them weak seat pressure and stupid (350#+) open pressure, or simply not enough room for even .500" for the newer stuff. Check your installed height and buy the appropriate single spring.
  10. nuhmizer
    561
    May 18, 2006
    San Diego, CA
    Now thats good to know
