Best Way to Pull the Engine?
Discussion in 'Engine Topic' started by Blk+Orange79Z28, May 1, 2017.
  1. Blk+Orange79Z28
    Blk+Orange79Z28 Member
    57
    Jun 15, 2016
    Eden Prairie, MN
    Hey everyone, pulling the engine out of my 79 Z this weekend, was wondering what ways work best for you guys to pull it. Would really like to keep the front bumper on. What have you guys done? What worked well and what didn't?
  2. COPO
    16,566
    306
    Pulled out together with the trans and installed the same way. No issues in my 70. Tied back my manifolds and A.I.R. pipes and PS pump. Rad was out, nothing else in the front needed to be removed. I even tested to see if I could get it in with the dizzy installed and yes it did.
  3. Vicious Z28
    Vicious Z28 Veteran Member
    113
    Mar 3, 2007
    Upper Marlboro MD
    I always pull the transmission but my new way to pull the engine is to remove one of the front tires and put it on a jack stand. Then I pull the motor with the jack on the side. No hurting the front bumper!
  4. Zspoiler
    Zspoiler Veteran Member
    2,740
    163
    May 6, 2012
    Federal Way, Washington
    I have pilled them out both ways .A lots depend on your engine hoist and just how much help you have.
  5. 351maverick
    351maverick Veteran Member
    3,347
    254
    Aug 11, 2010
    erie, PA
    a good engine hoist that rolls easily and a tilter really helps if the motor/trans are still mated
    this method will work as well:
  6. Coadster32
    1,475
    86
    Oct 2, 2013
    Milford,CT
    That's funny....I thought of this same video when I read the title of this thread.:crazy:
    Anyway...my motor came out with the trans in my 79 Camaro. 350/TH400 trans. No front bumper removed.
  7. 70-camaro
    70-camaro Veteran Member
    1,602
    259
    Mar 25, 2010
    marietta ohio
    Removed the front tire also and pulled from the side with distributor in, no cap.
  8. vegas1974z28
    4,610
    94
    Jan 10, 2002
    Las Vegas,NV
    IF you remove the front clip you can chase all the bolts put some WD40 on them and clean everything up as well. It takes me 90 min from running to motor in the back of the truck........A skill I am NOT proud of. If you click the link in my sig there are pictures. Also, I can put the motor in by myself. Just a thought, I know you said you didn't want to remove the bumper.
  9. COPO
    16,566
    306
    I also put my tranny jack which has 4 wheels under the tail of the tranny so it can slide back on it's own.
  10. slayer021175666
    slayer021175666 Veteran Member
    1,213
    57
    Feb 29, 2016
    Idaho
    I've always liked to pull the engine and transmission as one. Much easier than removing bell housing bolts. I use a spray paint can cap with duct tape to keep the fluid from pouring out the tail shaft housing and I set up the chain to give the engine a massive tilt upward to clear the radiator. Helps if you can jack up the front of the car, as well.
