Best 700 R4 transmission to rear end gear for a second generation Camaro
Discussion in 'High Tech Retrofits' started by patroll, Nov 14, 2017.
  1. patroll
    patroll Veteran Member
    102
    Nov 23, 2009
    Jackson,S.C.
    I want to , well sort of considering putting in a 700 R4 transmission because of the overdrive transmission to save on gas , what's a great gear in the rear-end to give you good gas mileage. But yet be able to get out there with the cars out there today and run with them . But easy on the gas mileage. Any suggestions here on this subject ? Or any suggestions .
  2. Rayzorz
    Rayzorz New Member
    Mar 28, 2017
    Calgary Alberta
    Try some online gear ratio/ top speed calculators. depending on your camshaft, engine size, tire diameter and "desired" cruise rpm at highway speed can alter your gear ratio decision. I'm running some 3.42's and 26" tall tires, that gives me a 22-2300 rpm cruise at 65 mph without lockup active on flat highway.
  3. SRGN
    SRGN Veteran Member
    519
    163
    Feb 20, 2009
    Central NJ
    All depends on the rest of the build.
  4. greencamaro1981
    greencamaro1981 Veteran Member
    604
    Jun 2, 2010
    Montana
    cruise at 65? our speed limit is 80 so in my 81 in 4th with 3.73 and 26 inch tire im running about 33-3500 rpm........ 8 mpg at best, but doing a 5.3 and 5speed swap this winter
  5. larrylarry
    larrylarry Veteran Member
    1,515
    67
    Dec 22, 2011
    San Antonio Tx
    A lot of it depends on your torque converter. I have 3.42’s in the rear, 2800 stall TQ, 700r4. It seems to me that I’m a bit too low in the power band, I need the rpm’s up around 2600 not at 2300 @ 70 mph like it is now. I could easily swap to 4.10 gears & be closer to the power band & still be around 26-2800 rpms @ 70 mph.
  6. Joekool
    Joekool Veteran Member
    5,901
    29
    Feb 4, 2002
    Hollister CA USA
    I have no problem cruising at 80 mph, 3000 rpm with 4.10's
  7. frank5s
    frank5s Veteran Member
    166
    Sep 6, 2008
    Naperville Il
    I was considering the same swap , what l read was 3.73 was the best all around . quick off the line and cruises like it has a 2.6 gear in rearend in overdrive.
    The transmission you want would be from a 1991 camaro.
    Just what l read.
    Frank
  8. CorkyE
    9,601
    276
    I have 3.73 behind a 700-R4, works well for me.
  9. frank5s
    166
    Sep 6, 2008
    Naperville Il
    To do the swap you will need a shorter driveshaft, a driveshaft from a mustang is the right size.
  10. accelo
    accelo New Member
    8
    Jan 12, 2015
    washington
    Easy to figure the rpm as the over drive ratio is a .7.
    .66 is a third, so divide your cruse RPM by 1/3.
    3000 rpm cruise is 2000 rpm with a 700R4 installed.
    Or another method is to mulitply the rear end ratio by .7.
    So a 4;11 will act like a 2.87 ratio with the overdrive.
