Belt squeal 79 Z
Discussion in 'Troubleshooting & Diagnosis' started by GPN, Jun 5, 2017.
  1. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    Loud squeeze when I start up. Squeal again when I give it gas first time. Then no more. My belts are new & newer
  2. Twisted_Metal
    25,990
    507
    Figure out which one is squealing with a little belt dressing. (That's all belt dressing is really good for. A bar of soap works too.)
    Spray one and start it.
    No squeal... You've found the culprit.
    Check tension (tighten, if needed) and look how it's riding in the pulley.
    V-belts use the sides of the belt for friction, if they bottom out in the pulley, they slip and squeal.
    I had a new belt which was made slightly narrow... That belt squeaked until I replaced it.
  3. cadillac_al
    cadillac_al Veteran Member
    648
    43
    Apr 22, 2015
    Maine
    I have had a couple alternators the last few years that did the same thing until they got worse. They used to squeal on start up, then quit with a stab of the gas pedal, then after a month squealing for 2-3 minutes. If your belt is new and tight, I would start suspecting the alternator.
  4. McCune
    McCune Veteran Member
    858
    125
    Aug 22, 2015
    st.george utah
    Loose belt, just tighten the alternator belt and you are good to go.
  5. Zspoiler
    Zspoiler Veteran Member
    2,684
    158
    May 6, 2012
    Federal Way, Washington
    Loose belt ,and sometimes the quality of the belts.
  6. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    You are right. My A/C belt is a bit loose--but the unit is maxed out on the adjustable....
    I know the belt is correct size for engine. Should I just try to purchase a belt a few mm shorter?
  7. Gary S
    21,271
    359
    Yes, I would try one a bit shorter if you have adjustment in the other direction.
  8. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    Thank you
