Be prepared, C-Prepared Autocross (1981 Camaro)
Discussion in 'Project Progress' started by 1981paul, Sep 11, 2008.
  1. Zspoiler
    Zspoiler Veteran Member
    2,692
    160
    May 6, 2012
    Federal Way, Washington
    I have a full set of Autometer Gauges as well A monster Tach with the shift light mounted in the cowl hood scoop .with a Matching Speedometer .A variety of 2 inch gauges mounted on a custom aluminum panel with a fuel pressure and boost gauge inside the cowl hood opening,
    1981paul likes this.
  2. 1981paul
    1981paul Moderator Staff Member
    Any photos? How easy is it to see them?
  3. Zspoiler
    2,692
    160
    May 6, 2012
  4. 1981paul
    Working on completing the dash as a sub-assembly, so when the time comes I can just bolt it in, connect a few wires, and it's done. This means I have to finish off the dash panel.
    It comes from S&W in a nice, bare aluminum, but I wanted to cut down on some glare and put a semi-gloss coating on it. I wanted a little more scratch resistance than paint, so I went with some 3M vinyl. People who like wrapping things in vinyl are masochists.
    So, of course, then I had to put it together.
    And, why not see what it looks like in the car?
    Last bit of wiring show up this week, so I can get this wrapped up and put away for now. Little bit of welding left to do over the weekend, and then it's paint prep time, I swear.
    Truck13 and John Wright like this.
  5. dutch73camaro
    dutch73camaro Veteran Member
    116
    13
    Jan 7, 2016
    Beverwijk, Netherlands
    love the progress
  6. 1981paul
    Paint prep is not that exciting to photograph, so I've also been nibbling away at little projects. One of those was giving the motor a little makeover.
    Randy built one hell of a motor, but all the beauty was on the inside. Since the motor was out of the car, I decided to help the outside. I used the POR-15 engine kit, and I hope it lasts considering the effort that went into it.
    Before:
    After:
    While watching paint dry is fun, I decided to do something even more fun - electrical! I've slowly been wiring the gauge cluster. My intent is to get this all done so it can just be installed as a unit later on down the road.
    I have been using the aircraft mentality of no solder - only butt connectors and shrink wrap. Hopefully that works out.
  7. Zspoiler
    2,692
    160
    May 6, 2012
    Very nice work
  8. z28cp
    z28cp Veteran Member
    334
    Jan 16, 2009
    Bellevue, NE
    Gettin' closer, Paul!!
  9. Randy 81
    Randy 81 Veteran Member
    898
    13
    Oct 28, 2009
    Loganville, Ga
    Looks great. I need to try the POR-15 kit on my next engine.
  10. John Wright
    14,270
    105
    Aug 9, 2002
    Rustburg, Va
    yeah, that POR kit looks good....let us know how it holds up over time
