badboys 70 project
Discussion in 'Project Progress' started by badboyrcg70, Jan 1, 2009.
  1. Turbo70Camaro
    2,127
    110
    Jan 7, 2005
    so cal
  2. badboyrcg70
    badboyrcg70 Veteran Member
    857
    Dec 30, 2008
    Reading, Pa
    Motor finally made its way in and actually had no issues with interference of the rack and pinion or the mid plate. Something finally went easy.
  3. JohnL71RS
    JohnL71RS Veteran Member
    1,627
    22
    Apr 12, 2010
    Marrero, LA
  4. badboyrcg70
    857
    Dec 30, 2008
    Reading, Pa
    Ugggg makes me sick to come here and not see a pictures!
  5. JohnL71RS
    1,627
    22
    Apr 12, 2010
    Marrero, LA
    i have been slowly migrating all to imgur
  6. badboyrcg70
    857
    Dec 30, 2008
    Reading, Pa
    Ill try them as well.
  7. 74fb461
    74fb461 New Member
    12
    Dec 8, 2013
    chippewa falls,wi
  8. badboyrcg70
    857
    Dec 30, 2008
    Reading, Pa
    Sorry for the delay in responding.
    Rack is set up to slope downward toward tie rod. 3/4-1" if I remember.
  9. 74fb461
    74fb461 New Member
    12
    Dec 8, 2013
    chippewa falls,wi
    Thanks NP, So was that at ride height or race height like how it sits going down the track? I was told to set it up at race height?
  10. badboyrcg70
    857
    Dec 30, 2008
    Reading, Pa
    Below are the instructions right off TRZ site. Mine were set at ride height before adding installing the motor.
    11. When adjusting for ‘bump steer’, you want to adjust the rod-end height to be as parallel as possible with the working angle of the control arms at race-weight and at ride height as a starting point. The working angle of the control arm is an imaginary line drawn between the pivot bolt in the frame and the ball portion of the ball joint. This is accomplished by adjusting which spacers are above and below the rod -end. Small changes from this location, either up or down, will effectively eliminate the ‘bump steer’. You will need to run the suspension through its entire travel for best results when doing this.
