Bad vibration
Discussion in 'Troubleshooting & Diagnosis' started by Fbomb, Jun 10, 2017.
  1. Overtrained
    Overtrained Veteran Member
    191
    Sep 10, 2015
    Merrick, NY
    What bell housing you running? Hows the pilot bushing look?
  2. 71 rs BBC
    71 rs BBC Veteran Member
    472
    65
    Nov 28, 2016
    Indy
    You said your lifters start clattering after it warms up? How's the oil pressure when that happens? The out of balance might be eating the mains and the more wear the worse the vibration. Read stories about balance jobs that were off.
  3. tom3
    tom3 Veteran Member
    11,108
    149
    Aug 1, 1999
    ohio
    My Camaro had a major vibration at 2500 rpm some years ago. Finally figured out it was the flywheel. Brand new Hayes billet that was like 50 grams out of whack. I'd guess your vibration at the higher 4000 rpm might be something else?
  4. Zspoiler
    Zspoiler Veteran Member
    2,686
    159
    May 6, 2012
    Federal Way, Washington
    Did you have a flywheel for a 400 cubic inch small block instead of a 350
  5. Crazy4camaro
    Crazy4camaro Veteran Member
    260
    34
    Dec 30, 2015
    Greenville SC
    Pull your belts off and check it in the garage.
  6. FlaJunkie
    6,066
    113
    Mar 24, 2001
    Rockledge, Florida
    First guess: Flywheel.
  7. 8pack
    2,390
    72
    Aug 29, 2007
    Pittsburgh, PA
    Yup....check the bell housing alignment while you have the trans out. Make sure it is dialed in and the run-out in all planes is good.
  8. Fbomb
    Fbomb New Member
    15
    Jan 1, 2013
    Ontario
    I removed the transmission an clutch. I think its this weighted ring on the clutch, you can see the witness marks where its been sitting. I'm worried that if I put this pressure plate back in that ring is just going to move back there. To answer some of your questions the fly wheel is for a 350, I ran this motor for two years and it was always great! Ran it with the belts off still vibrated, re set the valves to only 1/2 turn ( surprisingly this seemed to quite it down a bit...). Pilot bushing is being replaced while I have it apart. Thanks for all your help, Any suggestions on a better quality reasonably priced clutch?
    1970_Z28_503 likes this.
  9. Fbomb
    Fbomb New Member
    15
    Jan 1, 2013
    Ontario
    Vibration gone! I removed that weighted ring, installed a new pilot bushing and the car feels great, even the clutch pedal is smoother. I'll keep you all updated if I start having any clutch slippage.
  10. Calloushand
    Calloushand New Member
    12
    May 7, 2014
    Vancouver,WA
    Did you have to replace both? I am having the same issue. It's only just above idle. This is the 3rd motor I've had in it because of one thing or another. It runs great, has great oil pressure, and I've chased everything I could think of but still the vibration at 800-1500, It smooths out after that. I've had the wrong dampner on a internally balanced motor, and that shook like crazy at every RPM so I didn't think it would be the dampner.
