Autometer to factory harness
Discussion in 'Electrical Systems' started by $ Mike 70 Z-28, Oct 19, 2017.
  1. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    896
    11
    Nov 7, 2002
    New York, NY
    im installing the ultra liteII and looking for the best gauge harness to tap in the factory harness looking for your feed back
  2. buildinmy73
    buildinmy73 Veteran Member
    1,057
    8
    Oct 20, 2007
    Bernardston, MA
    I think most people just make their own harness. I didn't feel like it after doing a ton of wiring on my car from scratch. I bought a painless gauge harness. But all my wiring was painless brand and not original.
    You will have to cut off or tap into the wires coming from the original plug
  3. ULTM8Z
    ULTM8Z Veteran Member
    8,658
    154
    May 19, 2000
    Los Angeles
    You can look at how I did mine. I didn't want to cut my factory harness.
    Go to page 8...
    http://ultm8z.com/Installation write up.pdf
    The other end of the wires terminate into another connector. Make sure not to keep the soldering iron on the wires too long so as not to overheat/melt the factory connector. Just enough to tack solder the wires in place.
    99.9999999999999% I'll never go back to factory instrumentation, but if I ever did, I simply unsolder the wires from the terminals.
  4. $ Mike 70 Z-28
    896
    11
    Nov 7, 2002
    New York, NY
    THANKS FELLAS, is the painless labeled, ultm8z nice job
