? attaching door panel with a GOOD tight fit
Discussion in 'Interior Restoration' started by Chuck71RS, Feb 19, 2018.
  1. Chuck71RS
    1,094
    31
    Nov 24, 2012
    Houston, Texas
    The two front and back attachment points (the plastic tapered plugs in the door) barely hold or takes only a slight amount of pull to remove the panel.
    Sometimes the clips on the back of the door panel do not hold in the plug and/or the plug comes out. Even new plugs
    • expanded the two sides of the clips
    • wrapped a bit of ribbed duct tape on the plastic plugs
    The three along the top hold good and tight.
    Suggestions anyone?
  2. zeventy128
    zeventy128 Member
    41
    Jan 5, 2014
    Queensland
    Have heard of people starting to use strong magnets on door panels... Perhaps an option?
  3. 70 Proof
    70 Proof Veteran Member
    382
    26
    Sep 28, 2014
    Southern Utah
    In those problem spots that tend to not hold well you might try putting a square or two of Velcro on the back side of the door panel in those areas . Another possibility would be to use strong double sided carpet tape or some other strong adhesive material that won't come loose in the summer heat. OR for a positive hold use a chrome phillips head interior screw where necessary.
  4. Chuck71RS
    1,094
    31
    Nov 24, 2012
    Houston, Texas
    Some interesting ideas Bob. Chrome Phillips screws will be the last resort. Strong double sided tape or adhesive sounds promising.
