Are these rockers junk?
Discussion in 'High Performance Modifications' started by crome dome, Feb 21, 2011.
  1. crome dome
    crome dome Veteran Member
    525
    Oct 27, 2008
    Round rock Texas
    Why are these Comp Cams full roller rockers the same price as the stamped steel roller tipped ones? Will they break?
    http://www.summitracing.com/parts/CCA-17021-16/
    I am looking for a something to use in a street motor with .566 inch lift cam.
  2. 450bench
    450bench Veteran Member
    2,992
    17
    Feb 25, 2002
    memphis, tn-shelby
    They look like the old Cam Dynamics cast aluminum rockers...Work great on non-roller cams
  3. crome dome
    525
    Oct 27, 2008
    Round rock Texas
    Oops, I guess I should have mentioned I have a roller cam.
  4. mrdragster1970
    You have to be careful with cast stuff and high loads.
    I've used them in the past, because that's what they had back then,
    but a forged or billet piece will be stronger.
  5. hhott71
    hhott71 Veteran Member Lifetime Gold Member
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    You spent the dough for a roller cam lifters and springs, good heads and internals to make use of the roller cam and you want to skrimp the last $100 by not b]getting the PRO-Magnum Comp steel roller rockers?
    Might as well use a stock 12" converter and 2.41 single track gears and 225r 78x14 tires.
    Get real rockers, no need to chance the cast stuff on a HP vehicle.
    The high energy series rockers matches the High energy cams.
  6. 450bench
    2,992
    17
    Feb 25, 2002
    memphis, tn-shelby
    Don't be afraid of Harland Sharp roller rockers...They are the best, IMO, and are a shade over $200
  7. crome dome
    525
    Oct 27, 2008
    Round rock Texas
    Point taken.
    I did see some Harland Sharps for 250 but wondered if that was just another bottom of the line part with a good name on it.
  8. Mike-78 Z-28
    Mike-78 Z-28 Veteran Member
    1,905
    Mar 4, 2003
    ElDorado Arkansas
    The extruded aluminum rockers like Harland Sharp are much better than die cast.
  9. crome dome
    525
    Oct 27, 2008
    Round rock Texas
  10. frankz
    frankz Veteran Member
    2,072
    Aug 24, 2009
    Illinois
    What benefit would a roller rocker give in this application-5500rpm ?
