Applying Vinyl to package tray
Discussion in 'Interior Restoration' started by 8pack, Jan 27, 2018.
  1. 8pack
    2,450
    86
    Aug 29, 2007
    Pittsburgh, PA
    I had tried to do something different than just putting vinyl down in the package tray, but I couldn't get it to work out. So I went out and bought this vinyl called Trexx Vinyl and the pattern is pretty cool. In any even I am looking for insights on how best to apply it.
    I know about using 3M spray adhesive but I wanted to know the following:
    Is there a different product I should use?
    I am concerned about the vinyl lifting after time from the heat...should I tack the entire sheet down, or just the edges to it so it lays loose in the center and can't "lift" later....however, I think in the heat it may wrinkle if it is not glued down.
    Open to suggestions!
    Thanks
  2. xten
    xten Veteran Member
    2,093
    1,016
    Sep 24, 2014
    Pittsburgh, Pa.
    There's a couple different 3M ones. Is it porous? If it is, don't use the "Super" trim adhesive. It sometimes bleeds through porous material. I thought about you the other day, Bill. I was looking for something and ran across two brand new 6X9 speaker covers. Still in bags. They're yours if you want them. I wasn't sure what your final plan was.
  3. 8pack
    2,450
    86
    Aug 29, 2007
    Pittsburgh, PA
    Here's what I am using.....I don't think the vinyl is porous.
  4. 8pack
    2,450
    86
    Aug 29, 2007
    Pittsburgh, PA
    Thanks Phil! Hang onto them, I may still need them if I can't make what I am working on now work.....
  5. OrlandoMarkz28
    OrlandoMarkz28 New Member
    15
    Feb 23, 2009
    Orlando, FL
    Hey, I don't know about PA but here in FL the 3m stuff just melts in the summer the only thing I have found that worked was a contact cement I got from a upholstery guy that said this was the last he had and it is not made anymore, just a grey can no text at all but it worked perfect, over 5 years ago. I used the carbon fiber material with the peel off paper back and it is ok after 1 year on my package tray
  6. 8pack
    2,450
    86
    Aug 29, 2007
    Pittsburgh, PA
    Ok .I guess we will find out if the glue melts. That's would be a bummer. The good news is the tray itself can just be recoveredrif necessary as it is not likely to deteriorate as long as I own the car now.
