Anyone using the BRP Hotrods transmission crossmember and engine mounts?
Discussion in 'High Tech Retrofits' started by 1971CamaroGuy, Mar 2, 2018.
  1. 1971CamaroGuy
    3,580
    120
    Oct 31, 2004
    Arkansas
  2. badazz81z28
    14,957
    191
    Las Vegas, NV
    Looks Better then the BRP kit I played with years ago.
  3. 1971CamaroGuy
    3,580
    120
    Oct 31, 2004
    Arkansas
    Yeah I think the one's prior to that used a tubular cross-member maybe?
  4. carr911
    carr911 Veteran Member
    1,124
    228
    Mar 4, 2016
    Tampa, FL
  5. 1971CamaroGuy
    3,580
    120
    Oct 31, 2004
    Arkansas
    ok, I pulled the trigger on it, we'll see how it goes...I was wanting something that looks like it go be a factory installed part engineered together versus using the old traditional universal plates and crossmember
  6. badazz81z28
    14,957
    191
    Las Vegas, NV
    Is it steel or aluminum?
  7. 1971CamaroGuy
    3,580
    120
    Oct 31, 2004
    Arkansas
    supposed to be laser cut and welded steel as far as I can tell
  8. jkhall
    jkhall Member
    86
    Dec 5, 2017
    I got them. If you dont read the directions they are a bitch to get all lined up to fit. I also got the Hooker headers and the driver side header comes in contact with the driverside mount.
  9. 1971CamaroGuy
    3,580
    120
    Oct 31, 2004
    Arkansas
    Looks like they created the tracking label Sunday and hasn't started moving yet...I'll def post some detailed pics and steps when I get them in...along with any issues I run into.
    I'm off in a few weeks for spring break...I hope this ships soon because I was planning on doing all of this then.
    My concern is these kits are made to order and I am on a waiting list, surely not as they advertise these on eBay too.
  10. 1971CamaroGuy
    3,580
    120
    Oct 31, 2004
    Arkansas
    Looks like they updated the tracking today and I will get tommorrow..woo hoo!
