Any tips/tricks for removing a vinyl top?
Discussion in 'Body Restoration' started by G8RTYPELT, Feb 27, 2018.
  1. G8RTYPELT
    G8RTYPELT New Member
    Jun 7, 2012
    Birminham AL
    It's in pretty bad shape but the car and paint is pretty good. I peeked under the a pillar and the paint looks nice there too. Just wondering how big of PIA this will be. Thanks. Marty. 75 Type LT
  2. Revin
    Revin Veteran Member
    490
    65
    Aug 31, 2016
    Round Rock , TEXAS
    Tip....
    Get rid of it. Traps moisture.
    Not pretty under factory job later on. Fighting the rust on mine now
  3. Bikefixr
    Bikefixr Veteran Member Lifetime Gold Member
    1,745
    42
    Mar 13, 2006
    Beer....lots and lots of beer.
  4. 70 Proof
    70 Proof Veteran Member
    480
    42
    Sep 28, 2014
    Southern Utah
    Check Youtube for videos on vinyl roof removal.
  5. alpinemetal
    alpinemetal Member
    51
    Jul 5, 2014
    San Diego, CA
    Beer is good advice as is a garbage can close by...seen it done multiple times. Remove all the trim and just peal it off like the label of a pickle jar.
  6. Zstar
    Zstar Veteran Member
    1,378
    286
    Mar 23, 2014
    Ocala, Florida
    Spread paint thinner very liberally. Light. RUN!
  7. badazz81z28
    15,746
    278
    Las Vegas, NV
    I don't think peeling it back will be an issue if the paint was properly done. The glue will remain on the roof, but the vinyl will peel off. Your challenge will be to get the glue off...Not sure what would be effective and not cause the paint to come too.
  8. Jon balch
    Jon balch Veteran Member Gold Member
    214
    53
    Mar 29, 2017
    Upstate NY
    Wax and grease remover works pretty good at breaking down the glue
  9. Jon balch
    214
    53
    Mar 29, 2017
    Upstate NY
    Toluene Is what you want. I think I’ve seen it at Lowe’s or tractor supply. Use a spray bottle. Let it sit for a few minutes then wipe off
