Any issues with Griffin 870010LS 31.25" radiator hitting the steering gear?
Discussion in 'High Tech Retrofits' started by 1971CamaroGuy, Feb 26, 2018.
  1. 1971CamaroGuy
    1971CamaroGuy Veteran Member
    3,456
    82
    Oct 31, 2004
    Arkansas
    I'm looking at this radiator and noticed is 3" thick and 31.25" wide....I was wondering if anyone had any clearance issues with this hitting the steering gear or getting the cooler lines in ? Seems like this would hit the gear, or end up really close to it.
    Another concern is with it being that thick, does your air intake fit ok between the motor and radiator after adding a electric fan assembly? Planned on re-using my 4th gen fan set-up.
    https://www.ebay.com/itm/Gfin-Radiator-Crossflow-Dual-Row-Alum-31-25-Wide-18-62-High-3-0-Thick-870010LS/332213510622?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    They make a 26" version of this but it is on backorder for almost a month, but if there are going to be issues on the other, I may wait on the 26" one...I want it to drop in place with no clearance issues..I've had enough of that with other things
  2. Goat
    1,772
    19
    Jun 7, 2001
    moncure, NC
    Little confused about "hitting the steering gear"? Nothing that far forward having to do with steering in my 70...
  3. 1971CamaroGuy
    3,456
    82
    Oct 31, 2004
    Arkansas
    This spot highlighted, I was curious if that wide / deep radiator / Elec Fans / cooler line fittings /.....hit that spot on the steering gear?
  4. 1971CamaroGuy
    3,456
    82
    Oct 31, 2004
    Arkansas
  5. carr911
    carr911 Veteran Member
    814
    168
    Mar 4, 2016
    Tampa, FL
    The 1st Griffin I purchased from Summit did not fit (hit my Steering Box) - I returned it and Griffin made me a Custom one
    1971CamaroGuy likes this.
  6. LoweRider
    LoweRider Member
    45
    13
    Jun 26, 2017
    TX, USA
    Those are performance fit radiators, which state that some fabrication may be needed. I have that kit sitting in my garage waiting to go in my Z28.
  7. csjrishere
    csjrishere Veteran Member
    123
    Dec 7, 2010
    Pittsburgh, PA
  8. 1971CamaroGuy
    3,456
    82
    Oct 31, 2004
    Arkansas
    Dang that's pretty close!
  9. 1971CamaroGuy
    3,456
    82
    Oct 31, 2004
    Arkansas
    Ended up ordering this direct fit LS Radiator made by a company called Cold Case.
    Lifetime warranty and all of the connections are on the passenger side
  10. 1971CamaroGuy
    3,456
    82
    Oct 31, 2004
    Arkansas
    Got my cold case radiator in earlier...really liking it. This was a pretty good deal for $325 shipped I think...especially with the transmission cooler lines built in
    2018-03-09 14.27.07.jpg 2018-03-09 15.38.34.jpg 2018-03-09 15.38.41.jpg 2018-03-09 15.38.53.jpg 2018-03-09 15.39.04.jpg
