AN Hose Assembly Lube
Discussion in 'Tips 'n' Tricks Topic' started by badazz81z28, Aug 16, 2017.
  1. badazz81z28
    14,643
    159
    Las Vegas, NV
    Seems the stuff I bought from Summit is B/O for 2 months! Is it even needed to assemble hoses or is the stuff just oil?
    Thanks,
  2. CamaroGP
    CamaroGP Veteran Member Gold Member
    691
    89
    Nov 10, 2012
    Summerfield, Florida
    I use motor oil. I pore some in the cap and dip my finger in there and wipe it on the inner part of the fitting going into the line. I tried some spray silicone lube and WD-40 but I think the oil works best. No lube is needed if you are assembling PTFE lines.
  3. badazz81z28
    14,643
    159
    Las Vegas, NV
    They are Russell nylon braided hoses for my oil system.
  4. 71 rs BBC
    71 rs BBC Veteran Member
    472
    65
    Nov 28, 2016
    Indy
    Put some anti-sieze on the threads just in case you want to take them apart later.
  5. badazz81z28
    14,643
    159
    Las Vegas, NV
  6. 71 rs BBC
    472
    65
    Nov 28, 2016
    Indy
    Anti on the threads and oil on the part or nipple that goes into the hose. That's what I do now after the threads galled from just oil. You don't want anti seize in your hose. That stuff gets everywhere if you don't watch it. Lol!
  7. Turbo70Camaro
    2,127
    110
    Jan 7, 2005
    so cal
    white lithium grease on the male end while you push hose on, the grease travels up to the threads and tighten.
  8. CamaroGP
    691
    89
    Nov 10, 2012
    Remember the outside piece that goes over the braided line has left hand thread.
  9. badazz81z28
    14,643
    159
    Las Vegas, NV
    ^correct, some of the cheaper ones are just push on
  10. Turbo70Camaro
    2,127
    110
    Jan 7, 2005
    so cal
